340
accessing webdatechooser values in ultrawebgrid
I have a webdatechooser control assigned to multiple ultragrid columns. Everything works fine with the calendar and selecting dates.
However when I try and access the values via the rows of the grid it throws an exception when it hits the date column.
"Object reference not set to an instance of an object.
For Each row As Infragistics.WebUI.UltraWebGrid.UltraGridRow In DrawWebGrid1.Rows
       params(8) = New SqlParameter("@PStartDate", row.GetCellValue(DrawWebGrid1.Columns.FromKey("PStartDate")))
Next
If I stop in debug and look at the value set for that row it is the date string that was originally used
to initialize the field and not the data that appeared when the calander was clicked as if it did not bind to the grid somehow.
  • 28464
    "Object Reference Not Set To An Instance" could mean that any object in any part of the code sample could be null / not set to a reference. e.g. even the params collection or params(8) could be null. My suggestion is to break the code snippets into smaller parts (one at a line) and trace with a debugger to see what is going on.
