Product : Net Advantage 2008 Vol 3
igmenu_showMenu(ctlFlagOffer_menuId, event);
Works fine in IE, but doesnt not work at all in firefox. Is that part of latest hot fixes?
http://samples.infragistics.com/2008.3/WebFeatureBrowser/Default.aspx
If you open it in firefox and goto samples menus (poup), it doenst work there as well.
I'm using 8.3.20083.1009 and event I call igmenu_showMenu(mymenuID,null,0,0) to test but in Firefox , the page display nothing but work fine in IE. Any other idea?
Hello VMalinov,
The issue comes from the fact that FireFox does not have default "event" variable in the JavaScript engine. So when calling:
under FireFox, we are calling this function with NULL or very limited "event" bject.There are two approches here:
1. Explicitly supply X and Y coordinates (calculated by your logic) in this way:igmenu_showMenu(ctlFlagOffer_menuId, null, x, y);
2. This one will have limited applicability, but it will work in certain scenarios. The idea is to get the original browser's event when calling igmenu_showMenu(). For example, if you havea button (or a link) with "onclick" handler defined like that:
<a href="#" onclick="myCustomFunction()" />and then you have your custom function, that calls igmenu_showMenu():
function myCustomFunction(){ // do my logic here ... igmenu_showMenu(var_with_id, event);}This should be changed to:
<a href="#" onclick="myCustomFunction(event)" />function myCustomFunction(e){ // do my logic here ... igmenu_showMenu(var_with_id, e);}
Now we have explicitly passed the original browser's event to our function, so we can pass it down to the igmenu_showMenu() function.
Hope this helps.
Same problem here with the same version.
Any update?
Please try to use this statement '<%= UltraWebMenu1.ClientID%>' to get client ID. If doesn’t helps contact developer support directly at: http://ko.infragistics.com/support/
Thanks.
