305
Problem with UltraWebGrid in a UltraWebTab
i hope somebody can give me a reason for that behavior. I use some grids in 3 tabs of a webtab control to display data (kind of wizard style).
I bind all tabs at once. So that alle three tabs and grids are loaded immediately.
If i debug the code i can see all the data in the grids data structures. So until here it looks fine.
ugrid.Rows(0).Cells(4).Text = "My Value"
This value i can see in PreRender as well. Also if i do a postback the value is still there after the Page_Load.
But the grid doesnt show the data. Its empty.
The wierd thing is... I have a drop down list to filter some data. It calls exactely the same to bind it.
ugrid.datasource = _data.GetRows()
ugrid.DataBind()
In this case, if the tab that contains the grid is selected and visible, this works and the grid is rendered correctely.
I cant find why this doesnt work. More strange is the fact, that my third tab owns 2 grids as well and those are most time shown correctely.
I hope you can give me some hints. I dont have any other ideas how i could figure out the reason for this behaviour.
Thanks a lot!
Using NetAdvantage 2008 Vol 3
