305
UltraWebMenu not displaying Sub-Menus on Server
Hi all,
Firstly my apologies for posting this question as I'm sure it has been posted before but I cannot seem to find the answer.
I have added a UltraWebMenu to my master page and it works perfectly in my dev environment (everything running locally on my machine).
When I upload the web app to the hosted web server the sub menus will not drop down when I hover over the menu items. I am guessing that I have a missing reference to a CSS class.. ? But which one I do not know.
Here is the UltraWebMenu Code I am using:
<ignav:UltraWebMenu ID="UltraWebMenu1" runat="server" BackColor="Black" FileUrl=""
                        Height="100%" JavaScriptFilename="" JavaScriptFileNameCommon=""
                        LeafItemImageUrl="" ParentItemImageUrl="" StyleSetName="" TargetFrame="" TargetUrl=""
                        TopAligment="Center" TopItemSpacing="Compact" Font-Bold="True">
                        <Styles>
                            <ignav:Style BorderStyle="Outset" BorderWidth="1px" CssClass="TopHover3" Cursor="Default">
                            </ignav:Style>
                            <ignav:Style BorderColor="Black" BorderStyle="Solid" BorderWidth="1px" CssClass="TopClass3">
                            </ignav:Style>
                        </Styles>
                        <IslandStyle BackColor="Black" BorderStyle="Outset" BorderWidth="2px" Cursor="Default"
                            Font-Names="MS Sans Serif" Font-Size="8pt" ForeColor="White">
                        </IslandStyle>
                        <HoverItemStyle BackColor="DarkBlue" Cursor="Default" ForeColor="White">
                        </HoverItemStyle>
                        <Images>
                            <ScrollTopDisabledImage Url="/Images/Menu/ig_menu_scrollUp_disabled.gif" />
                            <ScrollBottomDisabledImage Url="/Images/Menu/ig_menu_scrollDown_disabled.gif" />
                            <SubMenuImage Url="/Images/Menu/arrow_white.gif" />
                            <ScrollBottomImage Url="/Images/Menu/ig_menu_scrollDownWhite.gif" />
                            <ScrollTopImage Url="/Images/Menu/ig_menu_scrollUpWhite.gif" />
                        </Images>
                        <ItemStyle CssClass="MenuItemClass" ForeColor="White" Height="20px" />
                        <Items>
                            <ignav:Item TargetUrl="Home.aspx" Text="Home">
                            </ignav:Item>
                            <ignav:Item Text="Dictionaries">
                                <Items>
                                    <ignav:Item TargetUrl="UserDetails.aspx" Text="Users">
                                    </ignav:Item>
                                    <ignav:Item TargetUrl="dictXCons.aspx" Text="XCon">
                                    </ignav:Item>
                                    <ignav:Item TargetUrl="dictCounties.aspx" Text="Counties">
                                    </ignav:Item>
                                    <ignav:Item TargetUrl="dictLocations.aspx" Text="Locations">
                                    </ignav:Item>
                                    <ignav:Item TargetUrl="dictMethod.aspx" Text="Methods">
                                    </ignav:Item>
                                    <ignav:Item TargetUrl="dictSpecies.aspx" Text="Species">
                                    </ignav:Item>
                                    <ignav:Item TargetUrl="dictWindDirection.aspx" Text="Wind Direction">
                                    </ignav:Item>
                                </Items>
                            </ignav:Item>
                            <ignav:Item Text="Reports">
                                <Items>
                                    <ignav:Item TargetUrl="ReportSearch.aspx" Text="Reports Search">
                                    </ignav:Item>
                                    <ignav:Item TargetUrl="ReportCreate.aspx" Text="Create Report">
                                    </ignav:Item>
                                </Items>
                            </ignav:Item>
                        </Items>
                        <DisabledStyle CssClass="MenuDisabledClass" ForeColor="LightGray">
                        </DisabledStyle>
                        <Levels>
                            <ignav:Level Index="0" />
                            <ignav:Level Index="1" />
                        </Levels>
                        <SeparatorStyle BackgroundImage="/Images/Menu/ig_menuStandardSep.gif" CustomRules="background-repeat:repeat-x; " />
                        <ExpandEffects ShadowColor="LightGray" Type="Fade"></ExpandEffects>
                        <MenuClientSideEvents InitializeMenu="" ItemChecked="" ItemClick="" SubMenuDisplay=""
                            ItemHover=""></MenuClientSideEvents>
                    </ignav:UltraWebMenu>
I am using the APTCA dll's from Program files for the WebMenu control as the server is shared hosting.
Thanks in advance
