I am using three UltraWebGroupBox inside my UltraWebPanel. The border of these three boxes is cutting out. I want to change the width of all three group boxes at runtime.
I am trying to use folloeing code. But it showing me some error:
GroupBox1.width=WebPanel.width-20;
Any suggestions will be highly appreciated.
Thanks for your reply. But I want to set it at page load. It happens in IE8 only. Its working fine in all other browsers.
You can use the click event of button and set new width of WebGroupBox1 and WebPanel1. Please take a look at the sample code below:
protected void Page_Load(object sender, EventArgs e) { WebGroupBox1.Width = 100; WebPanel1.Width = 50; } protected void Button2_Click(object sender, EventArgs e) { WebGroupBox1.Width=1000; WebPanel1.Width = (int)(WebGroupBox1.Width.Value - 50); }
Hope this helps.Thanks.
