750
Column Header (Caption converting into Capital Letters)
Below is my sample code
<igtbl:UltraGridColumn BaseColumnName="Date" IsBound="True" Key="Date" NullText="NA">
                        <Header Caption="Date Test">
                            <RowLayoutColumnInfo OriginX="1" />
                        </Header>
                        <Footer>
                        </Footer>
                    </igtbl:UltraGridColumn>
The header of this column is showing "DATE TEST" instead of "Date Test".  Its converting all the alphabets into capital alphabets. How to show cation as it is.
  • 28464
    This is one of the strangest problems I have seen. As far as I can tell, wither the Caption gets changed somehow in codebehind, or there is a Css class the capitalizes the header. There is a Css rule for that, e.g.
    text-transform:capitalize;
    If this does not help, then maybe if you isolate a small subset of your project reproducing the problem and send it to developer support via the following link, we will be able to provide additional details.
    http://ko.infragistics.com/Support/default.aspx#Overview
