100
UltraWebGrid OnDblClick Index was outside the bounds of the array. error
When I double click on the row rather than an individual cell I get this exception:
[IndexOutOfRangeException: Index was outside the bounds of the array.]
   Infragistics.WebUI.UltraWebGrid.UltraWebGrid.RaisePostBackEvent(String eventArgument) +13535
   System.Web.UI.Page.RaisePostBackEvent(IPostBackEventHandler sourceControl, String eventArgument) +13
   System.Web.UI.Page.RaisePostBackEvent(NameValueCollection postData) +175
   System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +1565
It never even gets to my handler. Code is below:
<igtbl:UltraWebGrid ID="grdProducts" runat="server" Height="400px" Style
="left: -21px;
top: -4px"
Width="469px" OnDblClick
="grdProducts_DblClick">
<Bands
<igtbl:UltraGridBand
<AddNewRow View="NotSet" Visible
="NotSet">
</AddNewRow
</igtbl:UltraGridBand
</Bands
<DisplayLayout BorderCollapseDefault="Separate" Name="grdProducts" RowHeightDefault="20px" StationaryMargins
="Header"
StationaryMarginsOutlookGroupBy="True" TableLayout="Fixed" Version
="4.00">
<GroupByBox
<Style BackColor="ActiveBorder" BorderColor="Window"></Style
</GroupByBox
<ActivationObject BorderWidth="" BorderColor
<BorderDetails WidthLeft="0px" WidthRight="0px"
</ActivationObject
<FooterStyleDefault BackColor="LightGray" BorderStyle="Solid" BorderWidth
="1px">
<BorderDetails ColorLeft="White" ColorTop="White" WidthLeft="1px" WidthTop="1px"
</FooterStyleDefault
<RowStyleDefault BackColor="White" BorderColor="Gray" BorderStyle="Solid" BorderWidth="1px" Font-Names="Verdana" Font-Size
="8pt">
<Padding Left="3px"
</RowStyleDefault
<FilterOptionsDefault
<FilterHighlightRowStyle BackColor="#151C55" ForeColor
="White">
</FilterHighlightRowStyle
<FilterDropDownStyle BackColor="White" BorderColor="Silver" BorderStyle="Solid" BorderWidth="1px" CustomRules="overflow:auto;" Font-Names="Verdana,Arial,Helvetica,sans-serif" Font-Size="11px" Height
="300px">
<Padding Left="2px"
</FilterDropDownStyle
</FilterOptionsDefault
<HeaderStyleDefault BackColor="LightGray" BorderStyle
="Solid">
</HeaderStyleDefault
<EditCellStyleDefault BorderStyle="None" BorderWidth
="0px">
</EditCellStyleDefault
<FrameStyle BorderStyle="Solid" BorderWidth="1px" Font-Names="Verdana" Font-Size="8pt" Height="400px" Width
="469px">
</FrameStyle
<Pager
<Style BackColor="LightGray" BorderStyle="Solid" BorderWidth
="1px">
BorderDetails ColorTop="White" WidthLeft="1px" WidthTop="1px" ColorLeft="White"></
BorderDetails>
Style
</Pager
<AddNewBox
<Style BackColor="Window" BorderColor="InactiveCaption" BorderStyle="Solid" BorderWidth
="1px">
BorderDetails>
Style
</AddNewBox
</DisplayLayout
</igtbl:UltraWebGrid><br
protected void Page_Load(object sender, EventArgs e)
XmlDataSource1.Data =
BSHFactory.GetProductList();
grdProducts.DataSourceID =
"XmlDataSource1";
grdProducts.DataBind();
grdProducts.Columns[0].Hidden =
true;
grdProducts.Columns[1].CellStyle.TextOverflow = Infragistics.WebUI.UltraWebGrid.
TextOverflow.Ellipsis;
grdProducts.Columns[1].Width =
Unit.Pixel(150);
grdProducts.Columns[2].CellStyle.TextOverflow = Infragistics.WebUI.UltraWebGrid.
grdProducts.Columns[2].Width =
Unit.Pixel(500);
grdProducts.Columns[3].Width =
Unit.Pixel(150);
grdProducts.Width =
Unit.Pixel(803);
foreach (UltraGridRow r in grdProducts.Rows)
r.Cells[3].TargetURL =
'@' + r.Cells[3].Text;
protected void grdProducts_DblClick(object sender, ClickEventArgs e)
if (e.Cell != null)
UltraGridRow row = e.Cell.Row;
Product p = BSHFactory.GetProduct(Int64.Parse(row.Cells[0].Text));
if (p != null)
lblMsg.Text = p.Description;
else
lblMsg.Text =
"Couldn't load product"
  • 28464
    As far as I can tell by looking at the code, it is a combined page lifecycle / databinding issue. Declarative datasources like XmlDataSource need to be set declaratively through the DataSourceID in the ASPX of the page, e.g.
    <igtbl:UltraWebGrid runat="server" ID="UltraWebGrid1" DataSourceID="XmlDataSource1" ... />
    This way, you will not need to explicitly bind the grid in Page_Load and i think this will address the issue.
