Is it possible to change the group by column on the client side using javascript? If so can you please provide an example.
Eric
Changing the grouping of a grid must be done on the server.
I've looked for any client-side function that would add (or remove) a column from grouping, and could not find one. Even if such a function existed, it would need to trigger a postback to work.
