180
Programaticly filling UltraWebTree from DataSet
I'm trying to fill WebTree from DataSet and I would like to know how to search for a node inside a Nodes collection, so I can use that node as a parrent to add other nodes to. I want only to search by the node's tag property.  My code is as follows:
public static Node populateUltraWebTree(DataSet ds)
        Nodes nodes = new Nodes();
        foreach (DataRow dr in ds.Tables[0].Rows)
            Node parentNode = null;
            Node currentNode = new Node();
            currentNode.Text = (string)dr["TEXT"];
            currentNode.Tag = dr["ID"];
            parentNode = nodes.Search(string.Empty,dr["PARENT_ID"],nodes[0], false);
            if (parentNode == null)
                nodes.Add(currentNode);
            else
                parentNode.Nodes.Add(currentNode);
        return nodes[0];
  • 180
    Verified Answer
    Ok, I've solved my problem by creating an XML file from the Data Set and than assigning NodeBinding to correctly read the XML data.
