I have a webgrid (version 7.3.20073.1061) where I need to format the text in each cell based on the row instead of the column. That is because each column contains the Avg value for the month & the type of value is the Row. (The grid shows sulfur content by month in a cross-tab type format.)
So, this is what I have done within the InitializeRow event:
Dim oCellDecimal As UltraWebGrid.UltraGridCell = e.Row.Cells.FromKey("DisplayDecimals")Dim intDecimals As Integer = 0If Not (oCellDecimal Is Nothing) AndAlso Not (oCellDecimal.Text Is Nothing) AndAlso IsNumeric(oCellDecimal.Text) Then intDecimals = CInt(oCellDecimal.Text)End IfFor Each oCell As UltraWebGrid.UltraGridCell In e.Row.Cells 'if the cell value is numeric & is one of the date or avg/min/max fields then set it's number of decimals accordingly If Not oCell.Value Is Nothing AndAlso oCell.Value.ToString.Length > 0 AndAlso IsNumeric(oCell.Value) Then Dim strFormat As String = "0.".PadRight(intDecimals + 2, "0") oCell.Text = Format(oCell.Value, strFormat) End IfNext
So each cell is rounded & displayed to the proper number of decimal places based on the values saved within the "DisplayDecimals" column.
However, if I get a number like "1.00" formatted, once the value gets to the screen, it shows up as "1". I am not setting any formatting at the column but it seems to still try to format it by stripping off the decimals places.
Please help. Is there a way to over-ride the formating at the column level?
Thanks!
So, if I set the columns for my averages as "System.String" instead of "System.Double" my decimal places stay formatted. I did this via the InitializeLayout event of the grid as:
UltraWebGrid.UltraGridColumn.DataType = "System.String"
I'd rather keep my datatypes as is so I would appreciate any other solutions... Thanks.
Tina
