340
UltraWebMenu 6.1 + ASP.NET 1.1 + IE 8
With the release of IE 8 I have been experiancing issues with the UltraWebMenu 6.1 running under .NET 1.1
The first issue was that access was denied to HM_Arrays.js (I dont get this error in versions of IE prior to 8, nor did I get it in the IE 8 Beta releases).
The Second error is that the UltraWebMenu does not show up at all (shows up in IE < 7 and was showing in beta versions of IE8) in IE 8 release.
I could only get the second error to occur after I managed to clear the first error by grating ASPNET and IIS_WPG full control of the website.
Just a further tidbit. We had issues using Response.Browser.JavaScript. Apperntly this will always return false for IE 8 release (we had to comment out code that was using it). I belive this is related to Microsoft not supporting the .NET 1.1 framework and as such did not update the framework code that tells Response.Browser.JavaScript that IE 8 is a supported browser that has javascript. Which means that the UltraWebMenu could be using this same code, determining that IE 8 doesnt support javascript and hiding itself.
