556
UpdateRow event does not fire on updates
I have an ultrwebgrid bound to a sqldatasource.  The UpdateRow event fires when I add a row, along with the AddRow event, but it does not fire when I update a row.  I think I have all the AllowUpdate type fields set.  The adding of rows run fine.  I have taken out the paging to simplify.  I can edit the lone updateable cell just fine.  I have a multiple field primary key, but it is supposed to handle it as I input  the fields, in the correct order, separated by commas in the DataKeyFields property.  I have attached the pertinent markup and C# code.
