I'm using a horizontal menu, urls point to a <IFRAME> beneath...gives impression of tabs...
Would like to have selected menu item highlighted when its selected and the page loads in the IFRAME below...how can I do this???
FYI , not using Tab Control because it doesn't allow for sub-tab menu...at least, not that I know how...
Please advise.
HI,
I created a sample project. I set the Webmenu's Item's TargetUrl to the page i wanted to display in the iframe. I set Item's TargetFrame to the Iframe Id
Here is my page.
<ignav:UltraWebMenu ID="UltraWebMenu1" runat="server" JavaScriptFilename="" JavaScriptFileNameCommon="" TargetFrame="" TargetUrl=""> <IslandStyle BackColor="LightGray" BorderStyle="Outset" BorderWidth="1px" Cursor="Default"> </IslandStyle> <TopSelectedStyle BackColor="Lime"> </TopSelectedStyle> <HoverItemStyle BackColor="DarkBlue" Cursor="Default" ForeColor="White"> </HoverItemStyle> <Images> <SubMenuImage Url="ig_menuTri.gif" /> </Images> <ItemStyle Cursor="Default" /> <Items> <ignav:Item Text="Top Item"> <Items> <ignav:Item Text="Default2" TargetFrame="if1" TargetUrl="Default2.aspx"> </ignav:Item> <ignav:Item Text="Sub Menu Item"> </ignav:Item> </Items> </ignav:Item> </Items> <DisabledStyle Font-Names="MS Sans Serif" Font-Size="8pt" ForeColor="Gray"> </DisabledStyle> <Levels> <ignav:Level Index="0" /> <ignav:Level Index="1" /> </Levels> <SeparatorStyle BackgroundImage="ig_menuSep.gif" CssClass="SeparatorClass" CustomRules="background-repeat:repeat-x; " /><ExpandEffects ShadowColor="LightGray"></ExpandEffects>
<MenuClientSideEvents InitializeMenu="" ItemChecked="" ItemClick="" SubMenuDisplay="UltraWebMenu1_SubMenuDisplay" ItemHover=""></MenuClientSideEvents> </ignav:UltraWebMenu> <iframe id="if1"></iframe> </div> </form></body></html>
Here is my 2nd page
<%@ Page Language="C#" AutoEventWireup="true" CodeFile="Default2.aspx.cs" Inherits="Default2" %>
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml"><head runat="server"> <title>Untitled Page</title></head><body> <form id="form1" runat="server"> <div> <asp:Label ID="Label1" runat="server" Text="Label"></asp:Label> </div> </form></body></html>
