I need help in setting up the grid with the following specification.
I have a table of routing information, which have Country and State. I also have a details table that holds the Country id, Destination id, and data (i.e. population, growth rate, etc.) corresponding to the selected Country and State information.
My question is, how do I set up a grid which have a column for each Country and State using dropdown lists or combo boxes? When I select a Country, the State list will automatically be updated with states that corresponde to the selected Country. I would like to save the data using the Country and State Id values, not the text values.
Thanks.
I'm just wondering if you finally get this thing to work because I have to do exactly the same thing as you. I know you were told to use the ajax pro library, is it working fine ? Or did you finally use another way of solving your issue ?
I'm asking you this because I'm not too familiar with Ajax and the answer was very straight forward so...
Philippe
hi,
you can use the great library AJAX.PRO from Michael Schwarz ->www.ajaxpro.info
you call the method on the server and then you write the result value into the dropdown control.
