If I add multiple series to a chart and the labels for the series don't completely sync up, it seems the data is rendered incorrectly. In the chart below series 1 has labels "Mark" and "Sue". Series 2 has labels "Mark" "Bob" and "Joe". When the chart is rendered I would expect the data to be treated as 4 rows: Mark, Sue and Bob, Joe. But instead, only 3 rows are displayed and the labels are Mark, Sue and "3". And Sue gets Bob's value for series 2.
It appears the chart is taking the first series as the basis for the rows, and then assuming the 2nd series has the same rows ordered in the same exact order. When there are more rows in a 2nd (or later) series, it does add a new row, but does not use the label associated with it.
I would expect it to use the label values to cluster the data, not the order of the data points in the series. This puts the burden of handling missing data on the code generating the multiple series of data, rather than handling in the chart.
<igChart:XamWebChart x:Name="XamWebChart1" Margin="10,0,0,0"> <igChart:XamWebChart.Series> <igChart:Series ChartType="Bar" Label="Series 1" > <igChart:Series.DataPoints> <igChart:DataPoint Value="50" Label="Mark" /> <igChart:DataPoint Value="40" Label="Sue" /> </igChart:Series.DataPoints> </igChart:Series> <igChart:Series ChartType="Bar" Label="Series 2" > <igChart:Series.DataPoints> <igChart:DataPoint Value="10" Label="Mark" /> <igChart:DataPoint Value="23" Label="Bob" /> <igChart:DataPoint Value="10" Label="Joe" /> </igChart:Series.DataPoints> </igChart:Series> </igChart:XamWebChart.Series></igChart:XamWebChart>
When I use this same series data with the Silverlight Toolkit charts, I get the results as I would expect. 4 clusters, 1 for Sue, Joe, Bob and Mark. Mark has data for both series, the rest only for 1. I can send a simple repro of that if needed.
So, I guess a couple questions:
1. Is this expected behavior, or a bug?2. If expected, is there a way I can get the behavior that the SL toolkit charts have, which is what I want?
Thanks,Keith
it's not in our immediate plans at this moment. you can submit your feature request here: http://devcenter.infragistics.com/protected/requestfeature.aspx
Thanks David. For #1, is there plans to address the limitation in the short or medium term (this quarter, this year)? I implemented #2 already, but would like to remove the extra processing code when possible.
1: this is expected ... there is a limitation in the current design where you cannot have uneven groups in column {& bar charts.
2: rearrange your data so that each series has a column for every possible person. as a side-effect, you will notice some space reserved on the x-axis for the missing entries (e.g. Joe in Series 1 or Sue in Series 2).
