Ok, I am trying to figure out how to ajax the groupby functionality of the webgrid. I tried the following... what am I missing?
using System;using System.Data;using System.Configuration;using System.Web;using System.Web.Security;using System.Web.UI;using System.Web.UI.WebControls;using System.Web.UI.WebControls.WebParts;using System.Web.UI.HtmlControls;using Infragistics.WebUI.UltraWebGrid;using LCF.BOL;using System.Web.SessionState;public partial class _Default : System.Web.UI.Page { protected void Page_Load(object sender, EventArgs e) { if (!this.IsPostBack) { AddUpcomingCareerFairs(); } } public void AddUpcomingCareerFairs() { this.WebGridUpcoming.DataSource = UpcomingCareerFairs.GetUpcomingCareerFairs(); this.WebGridUpcoming.DataBind(); } protected void WebGridUpcoming_InitializeLayout(object sender, Infragistics.WebUI.UltraWebGrid.LayoutEventArgs e) { // Properties needed to enable LoadOnDemand WebGridUpcoming.Browser = BrowserLevel.Xml; e.Layout.LoadOnDemand = LoadOnDemand.Xml; // LoadOnDemand configuration options e.Layout.RowsRange = 20; e.Layout.XmlLoadOnDemandType = XmlLoadOnDemandType.Accumulative; } protected void WebGridUpcoming_InitializeDataSource(object sender, Infragistics.WebUI.UltraWebGrid.UltraGridEventArgs e) { this.AddUpcomingCareerFairs(); } }
Put the UltraWebGrid in WebAsyncRefreshPanel.
