165
error in UltraWebTab
I try to use the UltraWebTab in my application, but I’m getting an error “Microsoft JScript runtime error: 'this._postBackSettings.async' is null or not an object” when I change between tabs.
Please help me how to avoid this error
<%@ Page Language="C#" AutoEventWireup="true" CodeFile="AssortmentDashBoard.aspx.cs"
    Inherits="AssortmentTools_AssortmentDashBoard" Title=":.Hendry Assortment Tools.: Assortment Tools"
    MasterPageFile="~/MasterPages/Hendry.master" %>
<asp:Content ID="AssortmentContent" ContentPlaceHolderID="BodyPlaceHolder" runat="server">
    <script language="javascript" type="text/javascript">
 function CollapseLeftNav()
        collapse();
    </script>
            <igtab:UltraWebTab ID="tabsAssortment" runat="server" EnableViewState="true" AutoPostBack="true" Height="680px" Width="99%"
                BarHeight="0" BorderWidth="0" OnTabClick="tabsAssortment_TabClick" >
                <DefaultTabStyle Height="20px" ForeColor="white" Font-Bold="true" />
                <RoundedImage FillStyle="LeftMergedWithCenter" HoverImage="../images/tab_hover.gif"
                    NormalImage="../images/tab_top_normal.gif" SelectedImage="../images/tab.gif" />
                <HoverTabStyle ForeColor="black">
                </HoverTabStyle>
                <Tabs>
                    <igtab:Tab Key="Recommend Assortment" Text="Recommend Assortment">
                    </igtab:Tab>
                    <igtab:Tab Key ="Compare Assortment" Text="Compare Assortment">
                    </igtab:Tab>
                    <igtab:Tab Key="Examine Assortment" Text="Examine Assortment">
                    </igtab:Tab>
                    <igtab:Tab Key="Share Scenarios" Text="Share Scenarios">
                    </igtab:Tab>
                </Tabs>
            </igtab:UltraWebTab>
</asp:Content>
And the code behind is as below.
public partial class AssortmentTools_AssortmentDashBoard : System.Web.UI.Page
    protected void Page_Load(object sender, EventArgs e)
        ((MasterPages_Hendry)this.Page.Master).PageTitle = "Assortment Tools Dashboard";
        ((MasterPages_Hendry)this.Page.Master).AddBodyAttribute("onload", "CollapseLeftNav()");
        if (Session["AddProduct"] != null)
            tabsAssortment.SelectedTabIndex = 1;
        else
            tabsAssortment.SelectedTabIndex = 0;
    protected void tabsAssortment_TabClick(object sender, Infragistics.WebUI.UltraWebTab.WebTabEvent e)
        if (e.Tab.Key.ToString() == "Compare Assortment")
            e.Tab.ContentPane.TargetUrl = "../AssortmentTools/CompareAssortment.aspx";
            tabsAssortment.DataBind();
    protected override void OnInit(EventArgs e)
        InitializeComponent();
        base.OnInit(e);
    private void InitializeComponent()
  • 24497
    The exception 'this._postBackSettings.async' is probably coming from the collapse() function which is called by CollapseLeftNav. The UltraWebTab or any Infragistics controls do not have variable with name _postBackSettings.
    I suggest you to insert in front of "collapse();" new line with "debugger;". When you debug page and hit that debug statement, then press F11. That may help you to figure out where exception is coming from, where _postBackSettings is used and why it is null.
