hi
i am using trial version of Infragistics and make a sample web application and add gridView control on my page ,but i am unable to lad the theme on my jsf page even default theme is no loaded.
here is web.xml file
////web.xml
<?xml version="1.0" encoding="UTF-8"?><!-- Copyright 2005 Infragistics. All rights reserved. Infragistics PROPRIETARY/CONFIDENTIAL. Use is subject to license terms.--><web-app version="2.4" xmlns="http://java.sun.com/xml/ns/j2ee" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://java.sun.com/xml/ns/j2ee http://java.sun.com/xml/ns/j2ee/web-app_2_4.xsd"> <description>Samples for Infragistics Component Studio</description> <display-name>Infragistics Component Studio - Samples</display-name> <context-param> <param-name>javax.faces.STATE_SAVING_METHOD</param-name> <param-value>server</param-value> </context-param> <context-param> <param-name>javax.faces.CONFIG_FILES</param-name> <param-value>/WEB-INF/navigation.xml,/WEB-INF/managed-beans.xml</param-value> </context-param> <!-- Listener to configure JSF. This listener is NOT required for most app servers as it is picked up automatically from the jsf jars. However some app servers such as Jetty, Resin, Oracle do NOT comply with the Servlet 2.3 Spec rule of calling listeners defined in tld files of a jar. It seems safe to call the listener even though it's correctly picked up by the app server. --> <listener> <listener-class>com.sun.faces.config.ConfigureListener</listener-class> </listener> <!-- Faces Servlet --> <servlet> <servlet-name>Faces Servlet</servlet-name> <servlet-class>javax.faces.webapp.FacesServlet</servlet-class> <load-on-startup> 1 </load-on-startup> </servlet> <servlet-mapping> <servlet-name>Faces Servlet</servlet-name> <url-pattern>*.faces</url-pattern> </servlet-mapping> <welcome-file-list> <welcome-file>index.jsp</welcome-file> </welcome-file-list> </web-app>
/// end of xml file
///and here is my jsp file
<%@ page contentType="text/html" language="java"%><%@ taglib prefix="f" uri="http://java.sun.com/jsf/core"%><%@ taglib prefix="h" uri="http://java.sun.com/jsf/html"%><%@ taglib prefix="ig" uri="http://ko.infragistics.com/faces/netadvantage"%><html><head><title>Infragistics NetAdvantage For Java Server Faces - Demo</title><meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1"><meta name="description" content="Infragistics NetAdvantage for Java Server Faces - Basic Grid Example"><link href="../../resources/default.css" rel="stylesheet" type="text/css"></head><body class="rightPanel"><f:view> <h:form> <h:panelGroup > <h:outputText value="WebGrid - Automatic Paging" /> <h:panelGroup ><%-- =================================== INFRAGISTICS-CODE ==================================== --%> <ig:gridView dataSource="#{webgrid_employeeDAO.employees}" pageSize="10"> <f:facet name="header"> <h:outputText value="Employee List" /> </f:facet> <ig:column> <f:facet name="header"> <h:outputText value="First Name" /> </f:facet> <h:outputText value="#{DATA_ROW.firstName}" /> </ig:column> <ig:column> <f:facet name="header"> <h:outputText value="Last Name" /> </f:facet> <h:outputText value="#{DATA_ROW.lastName}" /> </ig:column> <ig:column> <f:facet name="header"> <h:outputText value="Email" /> </f:facet> <h:outputText value="#{DATA_ROW.email}" /> </ig:column> <ig:column> <f:facet name="header"> <h:outputText value="Phone Number" /> </f:facet> <h:outputText value="#{DATA_ROW.phoneNumber}" /> </ig:column> </ig:gridView><%-- =================================== INFRAGISTICS-CODE ==================================== --%> </h:panelGroup> </h:panelGroup> </h:form></f:view></body></html>
///end of jsp file
i hav cpied all the jars and resources in my appp
plz help me
here my direcotry structur
i am using eclipse 3.1.0
jjboss-4.0.3SP1
jsf 1.1
thanx
What IDE and server are you using? If you're using Eclipse, be sure to clean your project, and rebuild it.
Once you have the resources folder in the right place, the themes will load automatically.
Best,Jim
hi roshan
i hav placed the Resources folder under the WebRoot folder but stll its bnot working ,,
plz take a close look at my files and tell me at where i am going to worng...
thank you
Hello Anjumpervaz,
You are placing the resources folder at incorrect place.
Resources folder should be under WebRoot.
Thank you.
