When I switch the Browser property to Xml from Auto and the LoadOnDemand property under DisplayLayout to Xml most of my formatting goes away.
For instance I have alternate row colors and the grid is rendered as white. I figured it had to do with a timing issue of what gets rendered when. I have tried moving the binding and the styling code around in the events with no success. When I set the grid back color to something weird you can see it around the edges but the grid rows are still white. Switching the Browser and LoadOnDemand properties back is the only way to correct the problem. I am using the RowUpdate server event to do some validation. Sure need this to work. Please help.
This is an internal application and we have standardized on IE 6 sp2. This is the only version I have tested it on. We are currenlty using Infragisitcs 2 v8.3. Thanks for your help.
Is this behavior browser specific? I was wondering if you have tested this with both IE and FireFox or not. What version of NetAdvantage you are using? Please let me know your response.
