1-I have a master page,
2-I have a user control for a webChart.
I want to use WARP in my page.
I have a button and when i click on it, new data will be generated for the webchart user control.
If i use the warp in a webForm page, i have no problem and the WARP wotks perfectly. But if i use a master page, the warp does not work.
Have you any idea?
Thank you in advance.
HI,
I could not reproduce your issue. I created a Master page - Content page had usercontrol with a chart and button. I ran the application and it worked as expected.
here is my master page:
<%@ Master Language="C#" AutoEventWireup="true" CodeFile="MasterPage.master.cs" Inherits="MasterPage" %>
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml"><head runat="server"> <title>Untitled Page</title> <asp:ContentPlaceHolder id="head" runat="server"> </asp:ContentPlaceHolder></head><body> <form id="form1" runat="server"> <div> <asp:Label ID="Label1" runat="server" Text="Master page"></asp:Label> <asp:ContentPlaceHolder id="ContentPlaceHolder1" runat="server"> </asp:ContentPlaceHolder> </div> </form></body></html>
Here my page:
<%@ Page Language="C#" MasterPageFile="~/MasterPage.master" AutoEventWireup="true" CodeFile="Default3.aspx.cs" Inherits="Default3" Title="Untitled Page" %>
<%@ Register assembly="Infragistics2.WebUI.Misc.v9.1, Version=9.1.20091.1015, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" namespace="Infragistics.WebUI.Misc" tagprefix="igmisc" %>
<%@ Register src="WebUserControl.ascx" tagname="WebUserControl" tagprefix="uc1" %>
<asp:Content ID="Content1" ContentPlaceHolderID="head" Runat="Server"></asp:Content><asp:Content ID="Content2" ContentPlaceHolderID="ContentPlaceHolder1" Runat="Server"> <igmisc:WebAsyncRefreshPanel ID="WebAsyncRefreshPanel1" runat="server" Height="320px" Width="380px"> <uc1:WebUserControl ID="WebUserControl1" runat="server" /> </igmisc:WebAsyncRefreshPanel></asp:Content>
Here is my user control
<%@ Control Language="C#" AutoEventWireup="true" CodeFile="WebUserControl.ascx.cs" Inherits="WebUserControl" %><%@ Register assembly="Infragistics2.WebUI.UltraWebChart.v9.1, Version=9.1.20091.1015, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" namespace="Infragistics.WebUI.UltraWebChart" tagprefix="igchart" %><%@ Register assembly="Infragistics2.WebUI.UltraWebChart.v9.1, Version=9.1.20091.1015, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" namespace="Infragistics.UltraChart.Resources.Appearance" tagprefix="igchartprop" %><%@ Register assembly="Infragistics2.WebUI.UltraWebChart.v9.1, Version=9.1.20091.1015, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" namespace="Infragistics.UltraChart.Data" tagprefix="igchartdata" %><igchart:UltraChart ID="UltraChart1" runat="server" BackgroundImageFileName="" BorderColor="Black" BorderWidth="0px" EmptyChartText="Data Not Available. Please call UltraChart.Data.DataBind() after setting valid Data.DataSource" Version="9.1"> <colormodel alphalevel="150" colorbegin="Pink" colorend="DarkRed" modelstyle="CustomLinear"> </colormodel> <axis> <pe elementtype="None" fill="Cornsilk" /> <x linethickness="1" tickmarkinterval="0" tickmarkstyle="Smart" visible="True"> <majorgridlines alphalevel="255" color="Gainsboro" drawstyle="Dot" thickness="1" visible="True" /> <minorgridlines alphalevel="255" color="LightGray" drawstyle="Dot" thickness="1" visible="False" /> <labels font="Verdana, 7pt" fontcolor="DimGray" horizontalalign="Near" itemformatstring="<ITEM_LABEL>" orientation="VerticalLeftFacing" verticalalign="Center"> <serieslabels font="Verdana, 7pt" fontcolor="DimGray" horizontalalign="Center" orientation="Horizontal" verticalalign="Center"> <layout behavior="Auto"> </layout> </serieslabels> <layout behavior="Auto"> </layout> </labels> </x> <y linethickness="1" tickmarkinterval="10" tickmarkstyle="Smart" visible="True"> <majorgridlines alphalevel="255" color="Gainsboro" drawstyle="Dot" thickness="1" visible="True" /> <minorgridlines alphalevel="255" color="LightGray" drawstyle="Dot" thickness="1" visible="False" /> <labels font="Verdana, 7pt" fontcolor="DimGray" horizontalalign="Far" itemformatstring="<DATA_VALUE:00.##>" orientation="Horizontal" verticalalign="Center"> <serieslabels font="Verdana, 7pt" fontcolor="DimGray" horizontalalign="Center" orientation="VerticalLeftFacing" verticalalign="Center"> <layout behavior="Auto"> </layout> </serieslabels> <layout behavior="Auto"> </layout> </labels> </y> <y2 linethickness="1" tickmarkinterval="10" tickmarkstyle="Smart" visible="False"> <majorgridlines alphalevel="255" color="Gainsboro" drawstyle="Dot" thickness="1" visible="True" /> <minorgridlines alphalevel="255" color="LightGray" drawstyle="Dot" thickness="1" visible="False" /> <labels font="Verdana, 7pt" fontcolor="Gray" horizontalalign="Near" itemformatstring="<DATA_VALUE:00.##>" orientation="Horizontal" verticalalign="Center" visible="False"> <serieslabels font="Verdana, 7pt" fontcolor="Gray" horizontalalign="Center" orientation="VerticalLeftFacing" verticalalign="Center"> <layout behavior="Auto"> </layout> </serieslabels> <layout behavior="Auto"> </layout> </labels> </y2> <x2 linethickness="1" tickmarkinterval="0" tickmarkstyle="Smart" visible="False"> <majorgridlines alphalevel="255" color="Gainsboro" drawstyle="Dot" thickness="1" visible="True" /> <minorgridlines alphalevel="255" color="LightGray" drawstyle="Dot" thickness="1" visible="False" /> <labels font="Verdana, 7pt" fontcolor="Gray" horizontalalign="Far" itemformatstring="<ITEM_LABEL>" orientation="VerticalLeftFacing" verticalalign="Center" visible="False"> <serieslabels font="Verdana, 7pt" fontcolor="Gray" horizontalalign="Center" orientation="Horizontal" verticalalign="Center"> <layout behavior="Auto"> </layout> </serieslabels> <layout behavior="Auto"> </layout> </labels> </x2> <z linethickness="1" tickmarkinterval="0" tickmarkstyle="Smart" visible="False"> <majorgridlines alphalevel="255" color="Gainsboro" drawstyle="Dot" thickness="1" visible="True" /> <minorgridlines alphalevel="255" color="LightGray" drawstyle="Dot" thickness="1" visible="False" /> <labels font="Verdana, 7pt" fontcolor="DimGray" horizontalalign="Near" itemformatstring="" orientation="Horizontal" verticalalign="Center"> <serieslabels font="Verdana, 7pt" fontcolor="DimGray" horizontalalign="Center" orientation="Horizontal" verticalalign="Center"> <layout behavior="Auto"> </layout> </serieslabels> <layout behavior="Auto"> </layout> </labels> </z> <z2 linethickness="1" tickmarkinterval="0" tickmarkstyle="Smart" visible="False"> <majorgridlines alphalevel="255" color="Gainsboro" drawstyle="Dot" thickness="1" visible="True" /> <minorgridlines alphalevel="255" color="LightGray" drawstyle="Dot" thickness="1" visible="False" /> <labels font="Verdana, 7pt" fontcolor="Gray" horizontalalign="Near" itemformatstring="" orientation="Horizontal" verticalalign="Center" visible="False"> <serieslabels font="Verdana, 7pt" fontcolor="Gray" horizontalalign="Center" orientation="Horizontal" verticalalign="Center"> <layout behavior="Auto"> </layout> </serieslabels> <layout behavior="Auto"> </layout> </labels> </z2> </axis> <effects> <effects> <igchartprop:GradientEffect /> </effects> </effects> <border thickness="0" /> <tooltips font-bold="False" font-italic="False" font-overline="False" font-strikeout="False" font-underline="False" /></igchart:UltraChart><asp:Button ID="Button1" runat="server" onclick="Button1_Click1" Text="Add Data" />
Here is my usercontrol code-behind.
using System;using System.Collections;using System.Configuration;using System.Data;using System.Web;using System.Web.Security;using System.Web.UI;using System.Web.UI.HtmlControls;using System.Web.UI.WebControls;using System.Web.UI.WebControls.WebParts;using Infragistics.UltraChart.Shared.Styles;using Infragistics.UltraChart.Resources.Appearance;using Infragistics.UltraChart.Core.Layers;
public partial class WebUserControl : System.Web.UI.UserControl{ protected void Page_Load(object sender, EventArgs e) { if (!Page.IsPostBack) { UltraChart1.DataSource = GetData(); UltraChart1.DataBind(); UltraChart1.Axis.Y.RangeMax = 6; UltraChart1.Axis.Y.RangeMin = 0; UltraChart1.Axis.Y.RangeType = AxisRangeType.Custom; } } protected void Button1_Click1(object sender, EventArgs e) { UltraChart1.DataSource = GetDatax(); UltraChart1.DataBind(); UltraChart1.Axis.Y.RangeMax = 6; UltraChart1.Axis.Y.RangeMin = 0; UltraChart1.Axis.Y.RangeType = AxisRangeType.Custom; }
private static DataTable GetData() { DataTable table = new DataTable(); table.Columns.Add("Label Column", typeof(string)); table.Columns.Add("sales", typeof(double)); table.Columns.Add("presales", typeof(double)); table.Rows.Add(new object[] { "Point A", 1.0, 3.0 }); table.Rows.Add(new object[] { "Point B", 2.0, 2.0 }); table.Rows.Add(new object[] { "Point C", 3.0, 1.0 }); table.Rows.Add(new object[] { "Point D", 4.0, 2.0 }); table.Rows.Add(new object[] { "Point E", 5.0, 3.0 }); return table; } private static DataTable GetDatax() { DataTable table = new DataTable(); table.Columns.Add("Label Column", typeof(string)); table.Columns.Add("Sales", typeof(double)); table.Columns.Add("Presales", typeof(double)); table.Rows.Add(new object[] { "Point A", 1.0, 3.0 }); table.Rows.Add(new object[] { "Point B", 2.0, 2.0 }); table.Rows.Add(new object[] { "Point C", 3.0, 1.0 }); table.Rows.Add(new object[] { "Point D", 4.0, 2.0 }); table.Rows.Add(new object[] { "Point E", 5.0, 3.0 }); table.Rows.Add(new object[] { "Point F", 6.0, 4.0 }); return table; } }
Thank you for your response,
In my senario, i don't have the Button in the usercontrol. I have to put it outside the usercontrol.
I tried your example by putting the button on the page, but it does not work;
Could you please try it.
Ok , in the WebUserControl - create a public method to add data to the chart
here is the code snippet:
public void refresh() { UltraChart1.DataSource = GetDatax(); UltraChart1.DataBind(); UltraChart1.Axis.Y.RangeMax = 6; UltraChart1.Axis.Y.RangeMin = 0; UltraChart1.Axis.Y.RangeType = AxisRangeType.Custom;
Now in the page with the warp - add your button and in the click method
put the folloiwng code
protected void Button1_Click(object sender, EventArgs e) { WebUserControl wuc1 = (WebUserControl) WebAsyncRefreshPanel1.FindControl("WebUserControl1"); wuc1.refresh(); }
Thank you for your response.
I bind the data to my webchart usercontrol dynamicly. i.e the refresh() method is not in my uer control but in my web page. in other word, i bind the data to my webchart usercontrol from the webpage and not from my usercontrol.
Do you think that it is possible to use the WARP in that case?
You can use the warp -
in your user control expose a public property that points to the chart inside of the user control
Here is the code snippet: from the user control
public UltraChart uc = null; protected void Page_Load(object sender, EventArgs e) { uc = UltraChart1;
now on your main page - wire up a button click event and have it access this new public property of the user control
Here is the code snippet: from your main page - where the data is coming from
private static DataTable GetData() { DataTable table = new DataTable(); table.Columns.Add("Label Column", typeof(string)); table.Columns.Add("sales", typeof(double)); table.Columns.Add("presales", typeof(double)); table.Rows.Add(new object[] { "Point u", 1.0, 3.0 }); table.Rows.Add(new object[] { "Point v", 2.0, 2.0 }); table.Rows.Add(new object[] { "Point w", 3.0, 1.0 }); table.Rows.Add(new object[] { "Point x", 4.0, 2.0 }); table.Rows.Add(new object[] { "Point y", 5.0, 3.0 }); return table; } protected void Button3_Click(object sender, EventArgs e) { WebUserControl wuc1 = (WebUserControl)WebAsyncRefreshPanel1.FindControl("WebUserControl1"); wuc1.uc.DataSource = GetData(); wuc1.uc.DataBind();
Thank you for your response. In fact, i was did the same thing, before i send you my question, and it does not work. If it works for you, could you please send me the complete code.
Thank you .
Here is my project
