Setting AllowGroupBy.No on selected columns has no effect. I can still drag and group the disabled columns.
The grid is created as part of compisite control CreateChildControls override soon after a column is created as follows:
var col = new UltraGridColumn { Key = "ActualSize", BaseColumnName = "ACTUAL_SIZE", HeaderText = "Actual Size", DataType = "System.Decimal", Width = Unit.Pixel(100), CellStyle = { HorizontalAlign = HorizontalAlign.Right, Padding = { Right = Unit.Pixel(20) } }, HeaderStyle = { HorizontalAlign = HorizontalAlign.Right, Padding = { Right = Unit.Pixel(20) } }, AllowGroupBy = AllowGroupBy.No};
Thanks for the response
Babu
Hi
I have used the same propertly to disable grouping on few selected columns. Could you let me know at which point you have set this property.
Best Regards,
Vijay
