I tracked this msg to the following IG java script:
sequence of events:
Error: Syntax error
Error: Object expected
Error: 'Sys' is undefined
Error: Can't init editor
<script type='text/javascript'><!--igmenu_Header1InternalUltraWebMenu_Menu=[ "Header1:InternalUltraWebMenu",1,1,"","Header1InternalUltraWebMenuHover","Header1InternalUltraWebMenuTopSelected","/ig_common/WebNavigator31/ig_menuTri.gif",false,"300","100","Fade","#000000","5","200","1000","","","Header1InternalUltraWebMenuDisabled","Header1InternalUltraWebMenuItem","/ig_common/WebNavigator31/ig_menuBlueUp.gif","/ig_common/WebNavigator31/ig_menuBlueUp_disabled.gif","/ig_common/WebNavigator31/ig_menuBlueDown.gif","/ig_common/WebNavigator31/ig_menuBlueDown_disabled.gif",false,true,"","",true,false];
igmenu_Header1InternalUltraWebMenu_Events = [ ["",0],["",0],["",1],["",0],["",0]];
igmenu_initMenu('Header1InternalUltraWebMenu');//--></script><script type="text/javascript"><!--Sys.Application.initialize();// --></script><script type='text/javascript'><!--try{igedit_init("wcePrevious",5,"wcePrevious,,1,,,,0,1,1,,,0,0,,-1,",["","..",",","-","$","","$n","($n)",1,2,2,0,0,"","",3]);}catch(e){window.status="Can't init editor";}//--></script><script type='text/javascript'><!--try{igedit_init("wceCurrent",5,"wceCurrent,,1,,,,0,1,1,,,0,0,,-1,",["","..",",","-","$","","$n","($n)",1,2,2,0,0,"","",3]);}catch(e){window.status="Can't init editor";}//--></script><script type='text/javascript'><!--try{igedit_init("wnePrevious",4,"wnePrevious,,1,,,,0,1,1,,,0,0,,-1,",["","..",",","-","","","n","-n",1,2,0,0,0,"","",3]);}catch(e){window.status="Can't init editor";}//--></script><script type='text/javascript'><!--try{igedit_init("wneCurrent",4,"wneCurrent,,1,,,,0,1,1,,,0,0,,-1,",["","..",",","-","","","n","-n",1,2,0,0,0,"","",3]);}catch(e){window.status="Can't init editor";}//--></script></form> </body></html>
NetAdvantage 2006 Volume 3 CLR 2.0Infragistics2.WebUI.Shared.v6.3.dll6.3.20063.1069
Thx, XPXJ
The "Can't init edior" message means that the controls can't identify what JavaScript they need to run to initialize and thus function. Chances are high that the previous three errors are preventing the JavaScript from being found.
The "Syntax error" and "Object expected" messages are too generic for me to propose possible c***
The "'Sys' is undefined" message suggests that you may have placed some ASP.NET AJAX Extensions controls on your page (such as a ScriptManager) without having an "AJAX Enabled Website." If you're using a ScriptManager and if it's not able to initialize, this could cause our controls to be unable to initialize.
