264
Add Data from WebCombo to WebGrid...
Don't know if this is the correct forum to ask this in.  It may be a webgrid question.
What I am trying to do is the following:
I currently have a grid that an admin uses for security to a web application.  Names and information is manually typed in.  Obviously there is a chance for error and someone not be able to access the application.
I have created a WebCombo that queries our HR table to bring back data for a user name that is typed in.
What I would like to do is add a button that adds a new row to my grid with the data from the combo box.  I don't want to add the data to the database yet, because one the row is added, there are some other options that the admin can choose via checkboxes.
I have the grid in a WARP panel and I can add a blank row using Me.gridname.Rows.Add() when I click the WebImageButton.
Any ideas or direction would be greatly appreciated.
I have attached an image so that you can see what I want to do.
Thanks.
Doyen Blair
  • 29417
    Hello Doyen,
    I know it’s been a while since you posted your question but if you still need help with this I’d be glad to offer some assistance. I believe this discussion will benefit other community members as well.
    I’ve prepared a sample that I think reflects you scenario. I’m using the following code for the adding of the rows (for the OnClientClick of the button):
       function add() {
                  var grid = igtbl_getGridById("grid");
                  var combo = igcmbo_getComboById("WebCombo1");
                  //definethe strings you'll add to the grid
                  var text1 = combo.getDataValue();
                  var text2 = combo.getDisplayValue();
                    var newRow = igtbl_addNew(grid.Id, 0);
                    var id = newRow.Id;
                    newRow.cells[0].setValue(text1);
                    newRow.cells[1].setValue(text2);
    Please refer to the attached sample as well. If you have any questions don't hesitate to ask.
    Best Regards,
    Maya Kirova
    Developer Support Engineer
    Infragistics, Inc.
    AddDataWebComboToWG.zip
