Hello
In my webgrid, when i set the Multiple Data Key Fields, can not cause the updatecell event to fire
<igtbl:UltraWebGrid ID="UltraWebGrid1" runat="server" Height="200px" Width="325px" DataKeyField="CurrencyCode,ChangeDate" onupdatecell="UltraWebGrid1_UpdateCell"> <bands> <igtbl:UltraGridBand DataKeyField="CurrencyCode,ChangeDate" > <Columns> <igtbl:UltraGridColumn AllowUpdate="No" BaseColumnName="CurrencyCode" IsBound="True" > </igtbl:UltraGridColumn> <igtbl:UltraGridColumn AllowUpdate="No" BaseColumnName="ChangeDate" IsBound="True" DataType="System.DateTime"> <Footer> <RowLayoutColumnInfo OriginX="1" /> </Footer> <Header> <RowLayoutColumnInfo OriginX="1" /> </Header> </igtbl:UltraGridColumn> <igtbl:UltraGridColumn BaseColumnName="Rate" IsBound="True" DataType="System.Decimal"> <Footer> <RowLayoutColumnInfo OriginX="2" /> </Footer> <Header> <RowLayoutColumnInfo OriginX="2" /> </Header> </igtbl:UltraGridColumn> <igtbl:UltraGridColumn BaseColumnName="Memo" IsBound="True" > <Footer> <RowLayoutColumnInfo OriginX="3" /> </Footer> <Header> <RowLayoutColumnInfo OriginX="3" /> </Header> </igtbl:UltraGridColumn> </Columns> <addnewrow view="NotSet" visible="NotSet"> </addnewrow> </igtbl:UltraGridBand> </bands> <displaylayout allowcolsizingdefault="Free" allowcolumnmovingdefault="OnServer" allowdeletedefault="Yes" allowsortingdefault="OnClient" allowupdatedefault="Yes" bordercollapsedefault="Separate" headerclickactiondefault="SortMulti" name="UltraWebGrid1" rowheightdefault="20px" rowselectorsdefault="No" selecttyperowdefault="Extended" stationarymargins="Header" stationarymarginsoutlookgroupby="True" tablelayout="Fixed" version="4.00" viewtype="OutlookGroupBy" CellClickActionDefault = "Edit" > <framestyle backcolor="Window" bordercolor="InactiveCaption" borderstyle="Solid" borderwidth="1px" font-names="Microsoft S***rif" font-size="8.25pt" height="200px" width="325px"> </framestyle> <pager minimumpagesfordisplay="2"> <PagerStyle BackColor="LightGray" BorderStyle="Solid" BorderWidth="1px"> <borderdetails colorleft="White" colortop="White" widthleft="1px" widthtop="1px" /> </PagerStyle> </pager> <editcellstyledefault borderstyle="None" borderwidth="0px"> </editcellstyledefault> <footerstyledefault backcolor="LightGray" borderstyle="Solid" borderwidth="1px"> <borderdetails colorleft="White" colortop="White" widthleft="1px" widthtop="1px" /> </footerstyledefault> <headerstyledefault backcolor="LightGray" borderstyle="Solid" horizontalalign="Left"> <borderdetails colorleft="White" colortop="White" widthleft="1px" widthtop="1px" /> </headerstyledefault> <rowstyledefault backcolor="Window" bordercolor="Silver" borderstyle="Solid" borderwidth="1px" font-names="Microsoft S***rif" font-size="8.25pt"> <padding left="3px" /> <borderdetails colorleft="Window" colortop="Window" /> </rowstyledefault> <groupbyrowstyledefault backcolor="Control" bordercolor="Window"> </groupbyrowstyledefault> <groupbybox> <boxstyle backcolor="ActiveBorder" bordercolor="Window"> </boxstyle> </groupbybox> <addnewbox hidden="False"> <boxstyle backcolor="Window" bordercolor="InactiveCaption" borderstyle="Solid" borderwidth="1px"> <borderdetails colorleft="White" colortop="White" widthleft="1px" widthtop="1px" /> </boxstyle> </addnewbox> <activationobject bordercolor="" borderwidth=""> </activationobject> <filteroptionsdefault> <filterdropdownstyle backcolor="White" bordercolor="Silver" borderstyle="Solid" borderwidth="1px" customrules="overflow:auto;" font-names="Verdana,Arial,Helvetica,s***rif" font-size="11px" height="300px" width="200px"> <padding left="2px" /> </filterdropdownstyle> <filterhighlightrowstyle backcolor="#151C55" forecolor="White"> </filterhighlightrowstyle> <filteroperanddropdownstyle backcolor="White" bordercolor="Silver" borderstyle="Solid" borderwidth="1px" customrules="overflow:auto;" font-names="Verdana,Arial,Helvetica,s***rif" font-size="11px"> <padding left="2px" /> </filteroperanddropdownstyle> </filteroptionsdefault> </displaylayout> </igtbl:UltraWebGrid>
private DataSet _Data;private SqlCommand SelectCommand1;private SqlConnection con;private SqlDataAdapter da;
protected void Page_Load(object sender, EventArgs e) { if (!this.IsPostBack) { con = new SqlConnection(System.Configuration.ConfigurationManager.ConnectionStrings["ExpenseLineConnectionString3"].ConnectionString); _Data = new DataSet(); da = new SqlDataAdapter(); SelectCommand1 = new SqlCommand(); this.SelectCommand1.Connection = con; this.SelectCommand1.CommandText = "SELECT CurrencyCode,ChangeDate,Rate,Memo FROM TCurrencyRate"; this.da.SelectCommand = this.SelectCommand1; this.da.Fill(this._Data);
UltraWebGrid1.DataSource = _Data.Tables[0].DefaultView; this.UltraWebGrid1.DataBind(); } } protected void UltraWebGrid1_UpdateCell(object sender, Infragistics.WebUI.UltraWebGrid.CellEventArgs e) { string aa = ((object[])e.Cell.Row.DataKey)[0].ToString() + ((object[])e.Cell.Row.DataKey)[1].ToString();
I've received your message, Thomas - thanks for that.
Your case is connected to a development issue, 16500. This issue is currnetly "Awaiting Release" - this means that the issue has been internally fixed in our systems, our Quality Engineering team has verified the fis, and the fix will be included in the next service release for our ASP.NET controls.
According to the Service Releases page, we expect the next service release for our ASP.NET controls to be shipped on or about June 1, give or take a week.
For anyone else who's interested in this fix: you can either wait until we publish this next service release, or you can submit a support request to ask to be notified when this fix is published. If you submit a support request, I strongly recommend that you include a sample project that we can run and debug, so that we can be certain that the fix for this development issue also addresses the issue you're encountering.
Hi Vince,I have sent you an email about the support request.// thomas
Thomas,
Can you please send an email message to DSManager@infragistics.com to let me know what the case number on your support request is? I'm unable to identify the support request you've mentioned in this post, and I'd like to take a closer look at this. Thanks.
Using composite keys in Ultrawebgrid stopped working in release 8.3.20083.2059 and haven't worked since than!!! What to say about that !I have a issue in support request about this (and have priority support) but nothing happens. I now have to rebuild the DB, the datalayer and all webgrids to support only ONE field in the datakey. This bug, or undocumented breaking change ?, is a big backstep in the Ultrawebgrid and if it's a bug they would really have had a fix by now.//thomas
Can anyone help me?
