215
Ultrawebmenu
Ultrawebmenu gives script error in IE8. we are using  Infragestics version 8.3.
on click of any menu item  shows a script error at below line:
function igtbl_removeState(stateNode)
    while(stateNode.childNodes.length > 0)
Arati.
  • 275
    download the hot fix, this fixed that error but now my menus are opening going up past the top of the page, not down below the clicked menu  :(
  • 28407
    HI,
    I could not reproduce.
     Can you tell me what you want your menu click to accomplish?
     Here is my Aspx page - run this thru your system
    <%@ Page Language="C#" AutoEventWireup="true"  CodeFile="Default.aspx.cs" Inherits="_Default" %>
    <%@ Register Assembly="Infragistics35.WebUI.UltraWebNavigator.v8.3, Version=8.3.20083.1009, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb"
        Namespace="Infragistics.WebUI.UltraWebNavigator" TagPrefix="ignav" %>
    <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
    <html xmlns="http://www.w3.org/1999/xhtml">
    <head runat="server">
        <title>Untitled Page</title>
    </head>
    <body>
        <form id="form1" runat="server">
        <div>
            <ignav:ultrawebmenu runat="server" JavaScriptFilename=""
                JavaScriptFileNameCommon="" onmenuitemclicked="Unnamed1_MenuItemClicked">
                <islandstyle backcolor="LightGray" borderstyle="Outset" borderwidth="1px"
                    cursor="Default">
                </islandstyle>
                <hoveritemstyle backcolor="DarkBlue" cursor="Default" forecolor="White">
                </hoveritemstyle>
                <images>
                    <submenuimage url="ig_menuTri.gif" />
                </images>
                <ItemStyle Cursor="Default" />
                <Items>
                    <ignav:Item Text="Top Item">
                        <Items>
                            <ignav:Item Text="Sub Menu Item">
                            </ignav:Item>
                            </ignav:Item>
                            </ignav:Item>
                        </Items>
                    </ignav:Item>
                        <Items>
                            </ignav:Item>
                            </ignav:Item>
                            </ignav:Item>
                        </Items>
                    </ignav:Item>
                        <Items>
                            </ignav:Item>
                            </ignav:Item>
                        </Items>
                    </ignav:Item>
                </Items>
                <disabledstyle font-names="MS S***rif" font-size="8pt" forecolor="Gray">
                </disabledstyle>
                <levels>
                    <ignav:Level Index="0" />
                </levels>
                <SeparatorStyle BackgroundImage="ig_menuSep.gif" CssClass="SeparatorClass"
                    CustomRules="background-repeat:repeat-x; " />
    <ExpandEffects ShadowColor="LightGray"></ExpandEffects>
    <MenuClientSideEvents InitializeMenu="" ItemChecked="" ItemClick="" SubMenuDisplay="" ItemHover=""></MenuClientSideEvents>
            </ignav:ultrawebmenu>
        </div>
        </form>
    </body>
    </html>
    Code Behind
    using System;
    using System.Configuration;
    using System.Data;
    using System.Linq;
    using System.Web;
    using System.Web.Security;
    using System.Web.UI;
    using System.Web.UI.HtmlControls;
    using System.Web.UI.WebControls;
    using System.Web.UI.WebControls.WebParts;
    using System.Xml.Linq;
    public partial class _Default : System.Web.UI.Page
        protected void Page_Load(object sender, EventArgs e)
        protected void Unnamed1_MenuItemClicked(object sender, Infragistics.WebUI.UltraWebNavigator.WebMenuItemEventArgs e)
