I am having a problem with templated column used in multilevel grid with IE6.
When I collapse a band having any column as templated column, the band gets collapsed, but the dropdowns in templated column are not getting invisible. They remains at the same position as they were when band is expanded initially.
This problem is not there with IE7.
Attached herewith is the MS word file with repective screenshots.
Thanks.
