780
Axis Label text truncated if same number of characters but greater length.
In this chart, the axis label for "Southeast" gets truncated.  I think it's due to the fact that it's being measured as the same length as "Northwest" but takes a little more space due to the "S".
<igChart:XamWebChart x:Name="XamWebChart1" Grid.Row="0" >
 <igChart:XamWebChart.Series>
     <igChart:Series ChartType="Bar" Label="Hello" >
         <igChart:Series.DataPoints>
 <igChart:DataPoint Value="50" Label="Northwest"  />
 <igChart:DataPoint Value="40" Label="Southeast" />
         </igChart:Series.DataPoints>
     </igChart:Series>
 </igChart:XamWebChart.Series>
</igChart:XamWebChart>
Is there a way to pad the Label length so it has a little spare room to work with in these scenarios?  My data is dynamic, so I can't just handle this scenario.  If I put "Southeast " with a space at the end, it works, but if I try to add the " " to all label values ("Northwest "), then it still truncates the Southeast.
Note, if the larger width label (Southeast) is first, this doesn't happen.  But since I can't control the data, this doesn't help either.
Any ideas?  It seems like kind of a minor issue, but at the same time it makes the chart look bad for my client.  Thanks for any help!
- Keith
  • 28496
    Verified Answer
    i logged this as a bug and fixed it.  the bug # is 17214 - feel free to contact Infragistics Developer Support at any time to inquire about when the fix will be released.
    as a temporary workaround, try switching to a monospace font.
    <igChart:XamWebChart.Axes>
                    <igChart:Axis AxisType="PrimaryY">
                        <igChart:Axis.Label>
                            <igChart:LabelGroup FontFamily="Courier" />
                        </igChart:Axis.Label>
                    </igChart:Axis>
                </igChart:XamWebChart.Axes>
