Hi All,
I am very new to Infragistics and planning to use for one of our project after realizing that we cant go live without enhancing the look and feel.
I have a UltraGrid populated using a datatable
//bind data
public void BindGrid()
Grid_TitleDeeds.DataBind();
//get source
TDdataTable.Columns.Add(new DataColumn("TitleDeedNo",typeof(string)));
TDdataTable.Columns.Add(new DataColumn("Location", typeof(string)));
else
this.Grid_TitleDeeds.DisplayLayout.Bands[0].Columns[0].Width = Unit.Percentage(20);
this.Grid_TitleDeeds.DisplayLayout.Bands[0].Columns[1].Width = Unit.Percentage(20);
this.Grid_TitleDeeds.DisplayLayout.Bands[0].Columns[2].Width = Unit.Percentage(20);
this.Grid_TitleDeeds.DisplayLayout.Bands[0].Columns[3].Width = Unit.Percentage(40);
this.Grid_TitleDeeds.DisplayLayout.Bands[0].Columns[0].Footer.Caption = "<a href='BLOCKED SCRIPTigtbl_addNew(_clientGridID, 0).editRow()'> <img src='../../Images/AddButton.jpg' /></a>";
Grid is coming perfectly with row template for edit mode. I have added a button for adding new row. everything is working fine.
Now i need to add a button or a link for edit and delete. I have used this row template as a workaround for an issue. I am building an arabic application which is right to left. issue is cell edit is giving alignment problem if it is right to left. One more thing I noticed was after page postback all the style sheet applied to the grid is missing.
below is the grid code
<igtbl:UltraWebGrid ID="Grid_TitleDeeds" runat="server" OnInitializeBand="Grid_TitleDeeds_InitializeBand" OnInitializeLayout="Grid_TitleDeeds_InitializeLayout" OnInitializeRow="Grid_TitleDeeds_InitializeRow" Width="100%">
<Bands>
<igtbl:UltraGridBand ColFootersVisible="Yes">
<RowEditTemplate>
<table><tr><td align="left">
<asp:Label id="lbl1" runat="server" Text="©çê ںéè :" CssClass="ArabicLabel"></asp:Label>
</td><td>
<asp:TextBox id="editTitleDeedNo" runat="server" CssClass="TextBox" columnkey="TitleDeedNo"></asp:TextBox>
</td>
<td>
</tr>
<asp:Label id="lbl2" runat="server" Text="¢ں©ï¦ ںéè (ى¤©ï) :" CssClass="ArabicLabel"></asp:Label></td><td>
<asp:TextBox id="editDateIssued" runat="server" CssClass="TextBox" columnkey="DateIssued"></asp:TextBox>
<img src="../../Images/Calendar.gif" Width="20px" height="21px" /></td>
<tr>
<td align="left">
<asp:Label ID="Label9" runat="server" CssClass="ArabicLabel" Text="¢ں©ï¦ ںéè(êïéں§ï) :"></asp:Label></td>
<asp:TextBox ID="TextBox3" runat="server" columnkey="DateIssued" CssClass="TextBox"></asp:TextBox></td>
<asp:Label id="lbl3" runat="server" Text="êيçم ںéêéèï، :" CssClass="ArabicLabel"></asp:Label></td><td>
<asp:TextBox id="editLocation" runat="server" CssClass="TextBox" columnkey="Location"></asp:TextBox>
<asp:Label id="Label8" runat="server" Text="ں¥ ںéè :" CssClass="ArabicLabel"></asp:Label></td><td>
<asp:TextBox id="TextBox2" runat="server" CssClass="TextBox" columnkey="Owner"></asp:TextBox>
<td colspan="3" style="text-align: center">
<input id="Button1" onclick="igtbl_gRowEditButtonClick(event);" style="width: 50px"
type="button" value="OK" />
<input id="Button2" onclick="igtbl_gRowEditButtonClick(event);" style="width: 50px"
type="button" value="Cancel" /></td>
</table>
</RowEditTemplate>
<RowTemplateStyle BackColor="White" BorderColor="#139C47" BorderStyle="Solid">
<BorderDetails WidthBottom="3px" WidthLeft="3px" WidthRight="3px" WidthTop="3px" />
</RowTemplateStyle>
</igtbl:UltraGridBand>
</Bands>
<DisplayLayout AllowAddNewDefault="Yes" AllowColSizingDefault="NotSet" AllowDeleteDefault="Yes"
BorderCollapseDefault="Separate" CellClickActionDefault="RowSelect" CellPaddingDefault="1"
CellSpacingDefault="1" HeaderClickActionDefault="SortSingle" Name="ctl11xGridxTitleDeeds"
SelectTypeColDefault="Single" SelectTypeRowDefault="Single" TabDirection="RightToLeft"
TableLayout="Fixed" Version="4.00" AllowRowNumberingDefault="Continuous" ColWidthDefault="" >
<ActivationObject BorderColor="" BorderWidth="">
</ActivationObject>
<FilterOptionsDefault AllowRowFiltering="OnClient" FilterUIType="HeaderIcons">
</FilterOptionsDefault>
<RowSelectorStyleDefault BackgroundImage="../../ig_res/Trendy/images/tab_top_f.gif">
</RowSelectorStyleDefault>
<EditCellStyleDefault Width="100%">
</EditCellStyleDefault>
<FrameStyle Width="100%">
</FrameStyle>
</DisplayLayout>
</igtbl:UltraWebGrid>
Any help would be highly appreciated. I am stuck with this for the last 3 days trying different option.Client is very happy with current look and feel and wants to continue with these controls
Shajid
About the stylesheet try to link this using a reference tag on the HTML of the page, for example:
<LINK href="../xxxxxxx.css" type="text/css" rel="stylesheet">
Good Luck!
