This problem affects all editable WebCombos. They ignore the FieldLen and Format attributes. Here's another option...
Within InitializeCombo event call the following function:
hth
Hello Varlynstroud
You can use the property EditKeyDown of ClientSideEvents and use the javascript code below.
<div>
<igcmbo:WebCombo ID="WebCombo1" runat="server" Editable="true">
</igcmbo:WebCombo>
</div>
</form>
function Validation(comboId, comboString, button){
if(comboString.toString().length > 5){
return true;
return false;
</script>
Hope this helps.
Having the same issue here. Looks like it is not considered when the HTML input (type=text) is rendered and so no property is available for that.
One but not an elegant solution is to validation the rendered HTML input. I believe it is named with "_input" appended to the <WebComboClientID or Name> so something like WebCombo1_input. or maybe modify it's attribute at page load but as I've said not really elegant so hopefully Infragistics could shed light on this.
