If grid contains a lot of rows (about 200) it takes some (about 5) minutes to show in IE8. In other browsers (firefox, ie7) it takes some seconds.
We have open test site. Go to this url: http://edi-test.cislink.com. Then log in with: (login - valeria, pass - 6143006) and then open this url: http://edi-test.cislink.com/Pages/Document.aspx?orderid=134044&DisplayMode=Add&Type=Desadv
Try to repeat these steps in firefox and then in IE8 and you'll show.
So you have the issue with the 2009 Vol 1 service release. Please submit a support request with a sample @ http://ko.infragistics.com/support/default.aspx#Overview and our Developer Support Team will help you.
I've attached the response I got when tried to visit the WebSite.
Sarita
Thanks for quick reply. We use: NetAdvantage for Web Client 2009 Vol. 1<%@ Register assembly="Infragistics35.WebUI.UltraWebGrid.v9.1, Version=9.1.20091.2013, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" namespace="Infragistics.WebUI.UltraWebGrid" tagprefix="igtbl" %>
It's strange you can't visit site (http://edi-test.cislink.com/). Before we had not any problem with it.
Which version of NetAdvantage you are using? The UltraWebGrid released prior to 2009 Vol 1 is not compatible with IE8.
I could not visit the test site. I got the error message -- website can not be found. Please let me know if I need to do something special to view the website.
