I have two unbound checkbox column in the web grid. Only one of the checkbox should be selected for each row.
Problem: I am calling the client side method AfterCellUpdateHandler . Only this event gets fired when i check/uncheck the checkbox.
When the user checks the checkbox1 i want to uncheck the checkbox2 and vice versa. Whenever i uncheck the second checkbox its calling the "AfterCellUpdateHandler" again and again.
Please find my code below. I would appreciate help.
code:
function AfterCellUpdateHandler(gridName, cellId, button)
var oRow = igtbl_getRowById(cellId);
var cell = igtbl_getCellById(cellId);
var index = cell.Index;
var IsReject = new Boolean();
var IsSubmit = new Boolean();
// Checking for the cell Index
// The below method will be executed only for Index 0 & 1
RejectGridCell = oRow.getCellFromKey(
'Reject');
SubmitGridCell = oRow.getCellFromKey(
'Submit');
selectGridCell = oRow.getCellFromKey(
'CommodityCode');
alert(selectGridCell.getValue());
alert(RejectGridCell.getValue());
alert(SubmitGridCell.getValue());
IsReject =
new Boolean(RejectGridCell.getValue());
IsSubmit =
new Boolean(SubmitGridCell.getValue());
if (cell && cell.Band.Index === 0)
if(index == 0 && IsReject == true && IsSubmit == false )
alert(
'Un Check the Submit ');
SubmitGridCell.setValue(0);
if(index == 1 && IsSubmit == true && IsReject == false )
'Un Check the Reject');
RejectGridCell.setValue(0);
Thanks dude!!
It working coo!!!!
Try the overloaded .setValue function.
Use following:
SubmitGridCell.setValue(0,false);
This should not trigger the AfterCellUpdateHandler event again.
