20
Javascript error in UltraWebGrid
I am using NetAdvantage for .NET 2008 Vol. 1 CLR 2.0. I am getting an javascript error occationally when a edit operation is done in the UltraWebGrid.
I get the following error
"Object doesn't support this property or method"
in the source.axd file in the line editor.setValue(v,false); where the editor has a value elemID -1.
Below is the function name and code where I get the error. I have indicated the error line in bold.
function igtbl_editCust(g,v,r,col,cElem)
    var id=col.EditorControlID,editor=col.getEditorControl();
    if(editor==null && id!=null)
        if((editor=igtbl_getElementById(id))!=null)
            editor=editor.Object;
    if(editor==null)
        return null;
    col.editorControl=editor;
    var elem=editor.Element;
    g._ensureValidParent(editor);
    elem.style.zIndex=r.z;
    if (elem.tagName=="INPUT")
        if(g.IsXHTML)
            if (ig_csom.IsIE)
                r.x-=2;
                r.y-=2;
            var cStyle,eStyle;
            var wd=0,hd=0;
            if(ig_csom.IsIE)
                cStyle=cElem.currentStyle;
                eStyle=elem.currentStyle;
                wd=igtbl_parseInt(cStyle.borderLeftWidth)+igtbl_parseInt(cStyle.borderRightWidth)-igtbl_parseInt(eStyle.borderLeftWidth)-igtbl_parseInt(eStyle.borderRightWidth);
                hd=igtbl_parseInt(cStyle.borderTopWidth)+igtbl_parseInt(cStyle.borderBottomWidth)-igtbl_parseInt(eStyle.borderTopWidth)-igtbl_parseInt(eStyle.borderBottomWidth);
            else
                cStyle=cElem.style;
                eStyle=elem.style;
            if(r.w<0)r.w=1;
            if(r.h<0)r.h=1;
        else
            var frameBorderZero = (window.frameElement && window.frameElement.frameBorder == "0");
            if(ig_csom.IsIE && frameBorderZero)
                r.x+=2;
                r.y+=2;
            else if(ig_csom.IsFireFox)
                r.x+=1;
                r.y+=1;
    else if(ig_csom.IsIE && g.IsXHTML)
        r.x--;
        r.y--;
    if(ig_csom.IsFireFox && g.IsXHTML)
        r.y -= g.DivElement.scrollTop;
        r.x -= g.DivElement.scrollLeft;
    editor.setVisible(true,r.x,r.y,r.w,r.h);
    editor.webGrid=g;
    editor.addEventListener("blur",igtbl_hideEdit,g);
    editor.addEventListener("keydown",igtbl_hideEdit,g);
    elem.setAttribute("editType",4);
    g._editorCustom=editor;
    return elem;
The UltraWebGrid aspx code is as below which is placed inside an update panel. Normal 0 false false false EN-US X-NONE X-NONE MicrosoftInternetExplorer4 <igtbl:UltraWebGrid ID="UltraWebGrid1" runat="server" Width="100%" Height="340px" OnUpdateCell="UltraWebGrid1_UpdateCell">
                                <DisplayLayout AllowColSizingDefault="free" RowSelectorsDefault="No" RowHeightDefault="25px"
                                    Version="4.00" SelectTypeRowDefault="Single" BorderCollapseDefault="Separate"
                                    Name="UltraWebGrid1" StationaryMargins="Header" StationaryMarginsOutlookGroupBy="True"
                                    TableLayout="Fixed" CellClickActionDefault="Edit" AllowUpdateDefault="Yes" UseFixedHeaders="True">
                                    <ClientSideEvents AfterCellUpdateHandler="AfterCellUpdate" />
                                </DisplayLayout>
                                <Bands>
                                    <igtbl:UltraGridBand>
                                        <AddNewRow View="NotSet" Visible="NotSet">
                                        </AddNewRow>
                                    </igtbl:UltraGridBand>
                                </Bands>
                            </igtbl:UltraWebGrid>
<igtxt:WebNumericEdit ID="WebNumericEdit1" runat="server" Nullable="false">
                    </igtxt:WebNumericEdit>
                      <igtxt:WebNumericEdit ID="WebNumericEdit2" runat="server" Nullable="false">
I am setting the editor control id and type as below in the code behind Normal 0 false false false EN-US X-NONE X-NONE MicrosoftInternetExplorer4
EditorControlID = WebNumericEdit2.ID;
.Type = ColumnType.Custom;
 I have an update cell event which updates the values of the grid based on the newly entered value. When a user enters a new value and scrolls or clicks on other cells the editor text box does not scroll with the grid and gives a floating kind of a feel. Now when the user clicks on other cells we get the JavaScript error.
This error occurs occasionally and when I do multiple operations.
Kindly let me know what is cause and how I can fix this error.
Vikram
  • 120
    Hi Vikram ,
    Did you find any solution of this problem? I have same issue, if you can suggest any opinion on it.
    Thanks in advance,
    Manish Kakkar
