105
How to put check box inside a ultrawebgrid v 7.1
can any body tell me hoe to add a chackbox to a perticulat column in a grid
the idea is i need to give a grid displaying data and user will check the check box in multiple rows and atlast press save button then i need to save the value as true or false depending upon the checkbox checked.
  • 45049
    Suggested Answer
    The easiest way to put a checkbox column in your grid is to add a column whose DataType is "System.Boolean".  You may also want to change the column's Type property to CheckBox (Infragistics.Web.UI.UltraWebGrid.ColumnType.Checkbox).  To initialize the checked state for cells in this column, use a value of True for a checked checkbox and False for unchecked.
