205
Wow! LQQK Here (Video included) - Serious Issue With Moving Rows Up and Down. We're stumped!!!
Having an issue with the rowID never changing after initial click with following code:
(I have also attached a copy of the page)
Also, what is the equivalent for DataGrid1.SelectedIndex = iRank2;
protected void xlGrid_ItemCommand(object sender, Infragistics.WebUI.UltraWebGrid.UltraWebGridCommandEventArgs e)
            Int32 rowID = 0;
            DataRow dr1 = null;
            DataRow dr2 = null;
            Int32 iRank1 = 0;
            Int32 iRank2 = 0;
            Int32 iRank = 0;
            // convert the ParentControl to a CellItem object
            Infragistics.WebUI.UltraWebGrid.CellItem ci = e.ParentControl as
                Infragistics.WebUI.UltraWebGrid.CellItem;
            if (ci != null)
                // From the CellItem object, get the Row object
                Infragistics.WebUI.UltraWebGrid.UltraGridRow row = ci.Cell.Row;
                rowID = (Int32)row.Cells.FromKey("ActivityID").Value; <=PROBLEM AREA
                DataView dv = new DataView(dt, null, "Sequence", DataViewRowState.CurrentRows);
                for (Int16 i = 0; i < dv.Count; i++)
                    if (dv[i]["ActivityID"].Equals(rowID))
                        iRank = Convert.ToInt32(dv[i]["Sequence"]);
                        switch(e.InnerCommandEventArgs.CommandName.ToString())
                            case "MoveUp":
                                if (i > 0)
                                    //we cannot change the rank values otherwise the
                                    //the order of the rows in the DataView would
                                    //change because the DataView is sorted Rank
                                    //so we save those values till the end of the loop
                                    dr1 = dv[i].Row;
                                    dr2 = dv[i - 1].Row;
                                    iRank1 = (Int32)dv[i]["Sequence"];
                                    iRank2 = (Int32)dv[i - 1]["Sequence"];
                                break;
                            case "MoveDown":
                                if (i < dv.Count - 1)
                                    dr1 = dv[i].Row;
                                    dr2 = dv[i + 1].Row;
                                    iRank2 = (Int32)dv[i + 1]["Sequence"];
                                    dr1[
"Sequence"] = iRank2;
                                    dr2[
"Sequence"] = iRank1;
                                   dt.AcceptChanges();
                                break;
                if (dr1 != null && dr2 != null)
                    dr1["Sequence"] = iRank2;
                    dr2["Sequence"] = iRank1;
                    //DataGrid1.SelectedIndex = iRank2;
                    //xlGrid.selectedIndex = iRank2;
                Session["FilesOrder"] = dt;
                                break;
 So basically, if we click the up arrow it will move the row up and rebind - so far, so good.  Now when we click that same row, it will more the row above it up instead of the row we click.
In the event handler, this is getting populated with the same row even though we moved that row up!  It's very bizarre.
Here's a video to show you the behavior.  Note that row with Id 87 constantly moves up although we're not clicking that row...
