475
hide column
I have a requirement that requires variable number of columns. Can you use column width as the way to hide certain columns?
  • 1324
    Verified Answer
    Hello Yzbythesea,
    You can use the "rendered" attribute of the ig:column to deside wether you want to display or not. It takes a boolean value and setting its value to 'false' will not render the column.
    Hope it helps you.
    Roshan
