How to access the checkBox placed in Headertemplate ? Pls suggest.
First, get a reference to your column, cast to a TemplatedColumn object. Its HeaderItem property is a control container that will have the instance of whatever controls you had placed in your header template.
For example, in C#:
using Infragistics.WebUI.UltraWebGrid;...TemplatedColumn tc = ultraWebGrid1.Columns.FromKey("CheckboxCol") as TemplatedColumn;CheckBox cb = tc.HeaderItem.FindControl("HeaderCheckBox") as CheckBox; // Pass in the ID of your checkbox here
use versions this.
InfraGrid_Products.Columns.FromKey(
"Chk").Hidden = true;
