I want to had some Nodes in webTreeView DYNAMICLY and I want to be able to redraw the parent node for place my new nodes at the good position. AND how can I do to add multi level nodes?
thx
Gabriel
I have attached a sample application.
your code give me some errors:
NullReferenceException........
If the meaning of the good position is a specific position in an UltraWebTree, you can create a parent and child nodes insert dynamically at specific position using indexes :
Node n = new Node(); // create a parent node
n.Text = "New Node";
n.Nodes.Add(new Node("One", null)); // adding some child nodes
n.Nodes.Add(new Node("Two", null));
n.Nodes.Add(new Node("Three", null));
this.UltraWebTree1.Nodes[1].Nodes.Insert(2, n);
//this line inserts parent node with its children to child nodes collection of the second node in a tree.
