Hi
I am using ultrawebcombo(hierarical Grid is placed inside the webcombo). I am getting error in FF, row is null. Error occur in afterselectchange . wgrid.getActiveRow() it returns null in FF, but this is working fine in IE. Can any one help me for this error.
Thanks a lot ...
I achive this through
AfterCloseUp instead of Selected row change.
Thanks a lot
What is your scenario? I would be happy to assist you if you can attach some ASPX/ code behind and describe what functionality you expect from the control.
In the meantime you can checkout the new WebDropDown ASP.NET AJAX Infragistics control:
http://samples.infragistics.com/2009.1/WebFeatureBrowser/Default.aspx
It may better suit your needs and specific scenario.
Angel
