Can I hide the expansion indicator? I have a WebListBar in Explorer bar mode, and I would like to hide the indicators...
Bob
Thanks Nasa,
I also set the header click action to none. Is there anything else I should do?
The Group’s ExpansionIndicatorImage is not removable and there's no built-in mechanism to remove it. You can change the images of the expansion indicator with transparent image that blends with its background color.
