45
Display controls on tree nodes?
Is it possible to add controls at the node level?  For example I need to display a couple of buttons depending on the level of the node.  One a different level I need to display a combo-box and button.  I was thinking that perhaps there is some way of specifying a template like the templated data controls.
 Any suggestions kindly received.
Kevin White
  • 5118
    Hi Kevin,
     You can always inject markup to acheive these results...
    node.Text = "<input type='button' value='Button Text' />"
    the key here is knowing that you can inject markup anywhere there is a text property and the markup will render out.
