75
UltraWebGrid row selection scrolls window to top
When I click on a cell to edit (CellClickAction="Edit"), the window position doesn't move, no scrolling occurs. Everything is just fine, except my row isn't selected so my style for the background color of the row doesn't work. I want to know why selecting the cell or editing the cell doesn't by definition select the row.
To get around this, I tried to use RowSelect. When I set the cell to select the row (CellClickAction="RowSelect"), the window scrolls to the top so I can't see the row that's been selected any more and editing the cell becomes an exerise in futility. Note that it's the actual window that is scrolled -- if I set a height on the Grid, the scroll position in that piece is maintained properly but the whole window is scrolled to the top. When I have 2 grids on a page, this is a serious problem and prevents editing.
This is with the newest package, using IE8.  I want to know why editing the cell doesn't do the window scrolling thing, but selecting the row does. Obviously, selecting and editing the cell doesn't select the row (my first point), so what exactly happens on row selection that isn't happening on cell selection?
No matter what the cell mode, clicking on the row selector to select the row does exhibit this odd window scroll behavior.
Any help appreciated. I'm at my wits end with this control, it isn't doing anything I want it to do properly. Thanks!
ETA:
Scrolling issue on row selection easily recreated with the following example
<%@ Page Language="C#" AutoEventWireup="true" CodeFile="Default3.aspx.cs" Inherits="Default3"  MaintainScrollPositionOnPostback="true" %>
<%@ Register Assembly="Infragistics2.WebUI.UltraWebGrid.v9.1, Version=9.1.20091.1015, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb"
    Namespace="Infragistics.WebUI.UltraWebGrid" TagPrefix="igtbl" %>
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml" >
<head runat="server">
    <title>Untitled Page</title>
</head>
<body>
    <form id="form1" runat="server">
        Testing Infragistics<br />
        <asp:SqlDataSource ID="SqlDataSource1" runat="server" ConnectionString="<%$ ConnectionStrings:NorthwindConnectionString %>"
            DeleteCommand="DELETE FROM [Products] WHERE [ProductID] = @ProductID" InsertCommand="INSERT INTO [Products] ([ProductName], [SupplierID], [CategoryID], [QuantityPerUnit], [UnitPrice], [UnitsInStock], [UnitsOnOrder], [ReorderLevel], [Discontinued]) VALUES (@ProductName, @SupplierID, @CategoryID, @QuantityPerUnit, @UnitPrice, @UnitsInStock, @UnitsOnOrder, @ReorderLevel, @Discontinued)"
            SelectCommand="SELECT [ProductID], [ProductName], [SupplierID], [CategoryID], [QuantityPerUnit], [UnitPrice], [UnitsInStock], [UnitsOnOrder], [ReorderLevel], [Discontinued] FROM [Products]"
            UpdateCommand="UPDATE [Products] SET [ProductName] = @ProductName, [SupplierID] = @SupplierID, [CategoryID] = @CategoryID, [QuantityPerUnit] = @QuantityPerUnit, [UnitPrice] = @UnitPrice, [UnitsInStock] = @UnitsInStock, [UnitsOnOrder] = @UnitsOnOrder, [ReorderLevel] = @ReorderLevel, [Discontinued] = @Discontinued WHERE [ProductID] = @ProductID">
            <DeleteParameters>
                <asp:Parameter Name="ProductID" Type="Int32" />
            </DeleteParameters>
            <UpdateParameters>
                <asp:Parameter Name="ProductName" Type="String" />
                <asp:Parameter Name="SupplierID" Type="Int32" />
                <asp:Parameter Name="CategoryID" Type="Int32" />
                <asp:Parameter Name="QuantityPerUnit" Type="String" />
                <asp:Parameter Name="UnitPrice" Type="Decimal" />
                <asp:Parameter Name="UnitsInStock" Type="Int16" />
                <asp:Parameter Name="UnitsOnOrder" Type="Int16" />
                <asp:Parameter Name="ReorderLevel" Type="Int16" />
                <asp:Parameter Name="Discontinued" Type="Boolean" />
            </UpdateParameters>
            <InsertParameters>
            </InsertParameters>
        </asp:SqlDataSource>
        <br />
        <div style="position:relative;height:100%">
        &nbsp;<igtbl:UltraWebGrid ID="UltraWebGrid1" runat="server" DataMember="DefaultView"
            DataSourceID="SqlDataSource1" Height="100%" Width="600px">
            <Bands>
                <igtbl:UltraGridBand>
                    <Columns>
                        <igtbl:UltraGridColumn BaseColumnName="ProductID" DataType="System.Int32" IsBound="True"
                            Key="ProductID">
                            <Header Caption="ProductID">
                            </Header>
                        </igtbl:UltraGridColumn>
                        <igtbl:UltraGridColumn BaseColumnName="ProductName" IsBound="True" Key="ProductName">
                            <Header Caption="ProductName">
                                <RowLayoutColumnInfo OriginX="1" />
                            </Header>
                            <Footer>
                            </Footer>
                        <igtbl:UltraGridColumn BaseColumnName="SupplierID" DataType="System.Int32" IsBound="True"
                            Key="SupplierID">
                            <Header Caption="SupplierID">
                                <RowLayoutColumnInfo OriginX="2" />
                            </Header>
                            <Footer>
                            </Footer>
                        <igtbl:UltraGridColumn BaseColumnName="CategoryID" DataType="System.Int32" IsBound="True"
                            Key="CategoryID">
                            <Header Caption="CategoryID">
                                <RowLayoutColumnInfo OriginX="3" />
                            </Header>
                            <Footer>
                            </Footer>
                        <igtbl:UltraGridColumn BaseColumnName="QuantityPerUnit" IsBound="True" Key="QuantityPerUnit">
                            <Header Caption="QuantityPerUnit">
                                <RowLayoutColumnInfo OriginX="4" />
                            </Header>
                            <Footer>
                            </Footer>
                        <igtbl:UltraGridColumn BaseColumnName="UnitPrice" DataType="System.Decimal" IsBound="True"
                            Key="UnitPrice">
                            <Header Caption="UnitPrice">
                                <RowLayoutColumnInfo OriginX="5" />
                            </Header>
                            <Footer>
                            </Footer>
                        <igtbl:UltraGridColumn BaseColumnName="UnitsInStock" DataType="System.Int16" IsBound="True"
                            Key="UnitsInStock">
                            <Header Caption="UnitsInStock">
                                <RowLayoutColumnInfo OriginX="6" />
                            </Header>
                            <Footer>
                            </Footer>
                        <igtbl:UltraGridColumn BaseColumnName="UnitsOnOrder" DataType="System.Int16" IsBound="True"
                            Key="UnitsOnOrder">
                            <Header Caption="UnitsOnOrder">
                                <RowLayoutColumnInfo OriginX="7" />
                            </Header>
                            <Footer>
                            </Footer>
                        <igtbl:UltraGridColumn BaseColumnName="ReorderLevel" DataType="System.Int16" IsBound="True"
                            Key="ReorderLevel">
                            <Header Caption="ReorderLevel">
                                <RowLayoutColumnInfo OriginX="8" />
                            </Header>
                            <Footer>
                            </Footer>
                        <igtbl:UltraGridColumn BaseColumnName="Discontinued" DataType="System.Boolean" IsBound="True"
                            Key="Discontinued" Type="CheckBox">
                            <Header Caption="Discontinued">
                                <RowLayoutColumnInfo OriginX="9" />
                            </Header>
                            <Footer>
                            </Footer>
                    </Columns>
                    <AddNewRow View="NotSet" Visible="NotSet">
                    </AddNewRow>
                </igtbl:UltraGridBand>
            </Bands>
            <DisplayLayout AllowColSizingDefault="Free" AllowColumnMovingDefault="OnServer" AllowDeleteDefault="Yes"
                AllowSortingDefault="OnClient" AllowUpdateDefault="Yes" BorderCollapseDefault="Separate"
                HeaderClickActionDefault="SortMulti" Name="UltraWebGrid1" RowHeightDefault="20px" SelectTypeRowDefault="Single" StationaryMargins="Header"
                StationaryMarginsOutlookGroupBy="True" TableLayout="Fixed" Version="4.00" AllowAddNewDefault="Yes" SelectTypeCellDefault="Single">
                <FrameStyle BackColor="Window" BorderColor="InactiveCaption" BorderStyle="Solid"
                    BorderWidth="1px" Font-Names="Microsoft Sans Serif" Font-Size="8.25pt" Height="100%"
                    Width="600px">
                </FrameStyle>
                <Pager MinimumPagesForDisplay="2">
                    <PagerStyle BackColor="LightGray" BorderStyle="Solid" BorderWidth="1px">
                        <BorderDetails ColorLeft="White" ColorTop="White" WidthLeft="1px" WidthTop="1px" />
                    </PagerStyle>
                </Pager>
                <EditCellStyleDefault BorderStyle="None" BorderWidth="0px">
                </EditCellStyleDefault>
                <FooterStyleDefault BackColor="LightGray" BorderStyle="Solid" BorderWidth="1px">
                </FooterStyleDefault>
                <HeaderStyleDefault BackColor="LightGray" BorderStyle="Solid" HorizontalAlign="Left">
                </HeaderStyleDefault>
                <RowStyleDefault BackColor="Window" BorderColor="Silver" BorderStyle="Solid" BorderWidth="1px"
                    Font-Names="Microsoft Sans Serif" Font-Size="8.25pt">
                    <Padding Left="3px" />
                    <BorderDetails ColorLeft="Window" ColorTop="Window" />
                </RowStyleDefault>
                <GroupByRowStyleDefault BackColor="Control" BorderColor="Window">
                </GroupByRowStyleDefault>
                <GroupByBox>
                    <BoxStyle BackColor="ActiveBorder" BorderColor="Window">
                    </BoxStyle>
                </GroupByBox>
                <AddNewBox Hidden="False">
                    <BoxStyle BackColor="Window" BorderColor="InactiveCaption" BorderStyle="Solid" BorderWidth="1px">
                    </BoxStyle>
                </AddNewBox>
                <ActivationObject BorderColor="" BorderWidth="">
                </ActivationObject>
                <FilterOptionsDefault>
                    <FilterDropDownStyle BackColor="White" BorderColor="Silver" BorderStyle="Solid" BorderWidth="1px"
                        CustomRules="overflow:auto;" Font-Names="Verdana,Arial,Helvetica,sans-serif"
                        Font-Size="11px" Height="300px" Width="200px">
                        <Padding Left="2px" />
                    </FilterDropDownStyle>
                    <FilterHighlightRowStyle BackColor="#151C55" ForeColor="White">
                    </FilterHighlightRowStyle>
                    <FilterOperandDropDownStyle BackColor="White" BorderColor="Silver" BorderStyle="Solid"
                        BorderWidth="1px" CustomRules="overflow:auto;" Font-Names="Verdana,Arial,Helvetica,sans-serif"
                        Font-Size="11px">
                    </FilterOperandDropDownStyle>
                </FilterOptionsDefault>
            </DisplayLayout>
        </igtbl:UltraWebGrid>
</div>
    </form>
</body>
</html>
