125
WebNumericEdit Tooltip via JavaScript
I would like to access (set) tooltip text of WebNumericEdit using Javascript.
Is it, and what's interesting me more, how is that possible?
Regards
Peter R.
  • 24497
    Suggested Answer
    Hi Peter,
    The editor has public member variable Element which contains reference to the outer element (it can be INPUT or TABLE depending on buttons).
    So, you may set title attribute for it. You can get reference to editor using igedit_getById(clientID_ofEditor), or using first param in ClientSideEvents. Below is example to set initial tooltip and change it dynamically on value change.
    function WebNumericEdit1_ValueChange(oEdit, oldValue, oEvent)
     oEdit.Element.title = 'value in editor:' + oEdit.getValue();
    function WebNumericEdit1_Initialize(oEdit, oldValue, oEvent)
     oEdit.Element.title = 'my tooltip';
    </script>
    <igtxt:WebNumericEdit ID="WebNumericEdit1" runat="server">
       <ClientSideEvents ValueChange="WebNumericEdit1_ValueChange" Initialize="WebNumericEdit1_Initialize" />
    </igtxt:WebNumericEdit>
