I have a webgrid with 3 columns. One for description/name and another 2 for a start date and for an end date. I have used a BeforeRowUpdateHandler for validating. It does prompt me if the name column is blank or if the start date is greater than end date. However, if I enter a value in the name column and should save, I would get an error something about not locating the item since ID is null. I tried adding a BeforeRowInsertHandler but I couldn't get the row since the record is being added through the 'Add New' row. Here's the javascript I used.
function GridAddressTypes_BeforeRowUpdateHandler(gridName, rowId){ var row = igtbl_getRowById(rowId); var start_date = new Date(row.getCellFromKey("start_date").getValue()); var end_date = new Date(row.getCellFromKey("end_date").getValue()); var description = row.getCell(1).getValue(); if(description != null) { if(start_date > end_date){ window.alert("Start Date can't be greater than End Date"); return true; } return false; }else { window.alert("Description can't be blank."); return true; } }
How can I make this work? Thanks in advance. =)
