804
getSelectedNode in javascript didn't fire
I use the ultrawebTree methods (CSOM) getSelectedNode, but nothings happen. This is my function:
function changeImageSelectionne(treeView)
          var node = treeView.getSelectedNode();
In my ultrawebTree tag:
<ClientSideEvents NodeClick="changeImageSelectionne" />
  • 28407
    HI ,
    I am not sure where you created your treeview object.
     also  make sure the webtree's selectable property is set to "True"
     I could not reproduce. I created a sample page - I tested it and it works.
     aspx page:
    <%@ Page Language="C#" AutoEventWireup="true"  CodeFile="Default.aspx.cs" Inherits="_Default" %>
    <%@ Register assembly="Infragistics2.WebUI.UltraWebNavigator.v8.1, Version=8.1.20081.2161, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" namespace="Infragistics.WebUI.UltraWebNavigator" tagprefix="ignav" %>
    <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
    <html xmlns="http://www.w3.org/1999/xhtml">
    <head runat="server">
        <title>Untitled Page</title>
        <script type="text/javascript" id="igClientScript">
    var tree =  null;
    function UltraWebTree1_NodeClick(treeId, nodeId, button){
     //Add code to handle your event here.
       tree = igtree_getTreeById(treeId);
      var node =  igtree_getNodeById(nodeId);
      var level = node.getLevel();
       if (level == 1)
        tree.CancelPostBack = true;
       else tree.CancelPostBack = false;
    function UltraWebTree1_BeforeNodeSelectionChange(treeId, oldNodeId, newNodeId){
    function Button1_onclick() {
      var node = tree.getSelectedNode();
      alert(node.Id);
    function UltraWebTree1_InitializeTree(treeId){
    </script>
    </head>
    <body>
        <form id="form1" runat="server">
        <div>
            <ignav:UltraWebTree ID="UltraWebTree1" runat="server" DefaultImage=""
                HiliteClass="" HoverClass="" Indentation="20"
                onnodeclicked="UltraWebTree1_NodeClicked" oninit="Page_Load">
                <ClientSideEvents NodeClick="UltraWebTree1_NodeClick"
                    BeforeNodeSelectionChange="UltraWebTree1_BeforeNodeSelectionChange"
                    InitializeTree="UltraWebTree1_InitializeTree" />
                <Levels>
                    <ignav:Level Index="0" />
                </Levels>
                <Nodes>
                    <ignav:Node Text="Root Node">
                        <Nodes>
                            <ignav:Node Text="Child Node">
                            </ignav:Node>
                            </ignav:Node>
                        </Nodes>
                    </ignav:Node>
                        <Nodes>
                            </ignav:Node>
                            </ignav:Node>
                        </Nodes>
                    </ignav:Node>
                </Nodes>
            </ignav:UltraWebTree>
        </div>
        </form>
        <p>
            <input id="Button1" type="button" value="button" onclick="return Button1_onclick()" /></p>
    </body>
    </html>
