I am having a major problem in my project. I've a requirement where a webdialogwindow pops up with list of users and one of them can be selected and when hit "ok", I've server side code that runs behind to save the record....but now, the problem is that I am opening the dialog using client side script -
var dialog = $find("<%= WebDialogWindow1.ClientID %>")
dialog.set_windowState($IG.DialogWindowState.Normal);
OR dialog.show();
The server side events are not getting fired in this case (for the "Ok" server side button in the screen below). But, when I am opening the dialog using server side code or if I am keeping it open forever with window state set to normal at design time, the events fire. It's really problematic for me. Is there an issue with WebDialogWindow? Is there a workaround?
Kala
