Hi I am using ultrawebtree, I want to display the node with text in the below format:
+ I Category Categoryvalue
+ II CategoryII CategoryvalueII
when I set the node name with spaces, those white spaces are truncated, So I planned to use display node with html table with 3 columns to get the format. When I use HTML table I am getting space like above format but node value is.
i want the html table to be along with the tree node! Is it possible?
--Thanks in Advance
Vijatyanand
