105
UltraWebGrid Header Alignment Problem when using Fixed Headers & AppStyling
Here's my problem:
Here's My .aspx Code:
<igtbl:UltraWebGrid
    ID="UltraWebGrid1"
    runat="server"
    DataSourceID="SqlDataSource_sp_rs_Build_Study_Calendar"
    EnableAppStyling="True"
    StyleSetName="Office2007Black">
    <DisplayLayout Name="UltraWebGrid1"
        AllowColSizingDefault="Free"
        AllowSortingDefault="OnClient"
        HeaderClickActionDefault="SortSingle"
        RowHeightDefault="20px"
        StationaryMargins="Header"
        StationaryMarginsOutlookGroupBy="False"
        TableLayout="Fixed"
        Version="4.00"
        ViewType="Flat"
        RowSelectorsDefault="No" >
        <RowStyleDefault Font-Size="10pt">
            <Padding Left="3px" />
        </RowStyleDefault>
        <FrameStyle
            Width="100%">
        </FrameStyle>
    </DisplayLayout>
</igtbl:UltraWebGrid>
Here's my .aspx.vb code:
Private Sub UltraWebGrids_InitializeLayout(ByVal sender As Object, ByVal e As LayoutEventArgs) Handles UltraWebGrid1.InitializeLayout
        'Set Default Width
        e.Layout.Bands(0).DefaultColWidth = New Unit("100px")
        'Lock first column & set width & left h-align & Bold
        e.Layout.UseFixedHeaders = True
        e.Layout.Bands(0).Columns(0).Header.Fixed = True
        e.Layout.Bands(0).Columns(0).Width = New Unit("200px")
        e.Layout.Bands(0).Columns(0).CellStyle.Font.Bold = True
        e.Layout.Bands(0).Columns(0).CellStyle.BackColor = System.Drawing.ColorTranslator.FromHtml("#F3EDE0")
        'Set all other cells to center H-align
        Dim maxcount As Integer
        maxcount = UltraWebGrid1.Columns.Count() - 1
        Dim i As Integer
        For i = 1 To maxcount
            e.Layout.Bands(0).Columns(i).Header.Style.HorizontalAlign = HorizontalAlign.Center
            e.Layout.Bands(0).Columns(i).CellStyle.HorizontalAlign = HorizontalAlign.Center
        Next
        'Set Scrollbars
        e.Layout.ScrollBar = ScrollBar.Always
        e.Layout.ScrollBarView = ScrollBarView.Both
    End Sub 'UltraWebGrid1_InitializeLayout
Suggestions offered on http://forums.infragistics.com/forums/t/9062.aspx have had no effect.
Disabling AppStyling (EnableAppStyling="False") fixes the alignment problem, but is not an acceptable solution.
Disabling UseFixedHeaders (UseFixedHeaders="False") also fixes the alignment problem, but again this is not an acceptable solution.
Any ideas on what I can change in order to fix the alignment problem???
