VS2005, Infragistics 2006.3.1083, MS .net framework 2.0 with service pack 1.
This has become a big problem for me. I recently upgraded from version 2006.1 to 2006.3.1083. Also, the .net 2.0 service pack 1 was update by microsoft. I really do not know which of these updates to blame, but the net result (no pun intended) is that WebCombo inteferes with postback after the completion of an update or insert command from formview when the webcombo is on the respective edit or insert templates, when using an AJAX updatepanel. (I Know, lots of variables here, which is why I have been going crazy checking my own code for problems before realizing who the culprit was).
To recreate the scenario:
I want to know if anyone else has this problem, and if so were they able to move up another version to 2007 without any problems.
Tony,
Thanks for your interest. I have submitted this to the support staff. I am still waiting for a response. Meanwhile I have been taking each form that has the problem, strangely, some do and others do not, and swapping out the webcombo control for the far less flexible and useful ASP.net dropdownlist control. It was during this stage that I noticed that the webforms elicit strange behaviours if the value of the field does not exist in the dropdownlist values. I am now doubling back to check this out in the webcombos.
Neal
I've been trying to carve out time to give this a try myself, and I've been unable. I recommend you report this to our support team (http://ko.infragistics.com/gethelp) It sounds like a regression issue that we just recently fixed, but our support staff will be able to tell you better.
-Tony
