280
AfterRowActivate javascript error
ok, i have the javascript for the AfterRowActivate event.  I am getting an error on my page
Error: Object doesn't support this property or method
Code: 0
here is the script
function EnableDisableButtons() {             var grid = document.igtbl_getGridByID("ctl00_ContentPlaceHolder1_uwg_Schedule")                   var type = grid.Rows[grid.ActiveRow.Index].Cells[15].Text                   if (type != 'APPT') {                     document.getElementById('ctl00_ContentPlaceHolder1_ddlResults').disabled = true;                     document.getElementById('ctl00_ContentPlaceHolder1_btnSaveResult').disabled = true;                     document.getElementById('ctl00_ContentPlaceHolder1_btnContact').disabled = true;                     }                 else if (type = 'APPT') {                     document.getElementById('ctl00_ContentPlaceHolder1_ddlResults').disabled = false;                     document.getElementById('ctl00_ContentPlaceHolder1_btnSaveResult').disabled = false;                     document.getElementById('ctl00_ContentPlaceHolder1_btnContact').disabled = false;                     }
any ideas? I htink it is something simple, but i don't see it.
  • 280
    Verified Answer
    the answer was i wasn't passing anything into the js as required, i will paste everything back in...
    function EnableDisableButtons() should have been
    function EnableDisableButtons(tablename, itemname)
     var grid = igtbl_getGridById(tablename);
                    var row = igtbl_getRowById(itemname);
                    var cell = row.getCell(15).getValue();
                    if (cell != 'APPT') {
                    else if (cell = 'APPT') {
  • 2907
    Suggested Answer
    I could see syntax errors in the script.
    Try replacing var type = grid.Rows[grid.ActiveRow.Index].Cells[15].Text as follows:
    var type = grid.Rows.getRow(grid.getActiveRow().Index).getCell(15).getValue();
    I think this should remove script error.
    Use this link for online documentation of infragistics to get further details about client side object model (CSOM):
    http://help.infragistics.com/NetAdvantage/NET/2008.2/CLR3.5/
    In above link navigate: ASP.NET -> Clint side object model reference (CSOM) -> Web Grid CSOM -> Web grid CSOM
    Refer this link if you are using different version:
    http://ko.infragistics.com/support/documentation.aspx#OnlineDocumentation
    I hope this would help you.
