504
Questions regarding LoadOnDemand Issues
I have tree set up with LoadOnDemand=Manaual; everything works fine except few scenarios
1. When page loads and tree populates the Parent Nodes. If i try to add a child node to any root node, which so far has not been populated from server, throws following error message
:Can't move focusto the control becauseit is invisible. not enabled, or of a type that does not accept the focus."
so question is how we can add a child to node which has not been populated with data from server
2. If i move a node A to a node B which again has not been populated from server, if Node B has children ( iam showing + sign programmitically for nopdes with children), then only dragged node is added and it does not show the children for Node B
3. If i add anew node and does not specify the text of it, i go to client side edit function where i check the length of the node in this case, it comes to 2, where as it shoudl be 0 as i did not tyoe in text. Then i wrote the custom Trim function and then i used it on the same node without text and then the length comes to 0. My question is that, when we add a node without specifying the text, why does the length is 2?
Hope of getting an early reply.
Rajan
